Question about Andis 01690 Hair Trimmer
Andis masters are chewing my guards
My andis masters eating or cutting little pieces of my speed 0 guards,I tried opening them and cleaning it out and removing the blades to if anything was bent or broken but everything seemed fine.
  • lace1829 Feb 16, 2009
    I took apart my andis speedmaster clippers for cleaning when i put it back together it makes a ginding noise and it doesn't cut well at all put it looks as if nothing is wrong
Stop using speedo guards and get yourself an oster 76 and all the blades.
Posted on Nov 12, 2007
  • 61 Answers
Remove and adjust blades back, just a tad
Posted on Jan 26, 2009
You need the metal guards at www.alexccampbell.com
Posted on Apr 15, 2008
Your blades are to flushed... u gotta adjust them a bit lower.
Posted on Mar 13, 2008
SOURCE:
Can I swap sharp cutting blade from one size blade to another?
Well you can either buy a new one from a local shop
http://www.angliaclipperservices.com/dog
Or wait a while and send them off for sharpening
http://www.angliaclipperservices.com/Clipper_Sharpening
May 26, 2016 | Andis Dog Clippers - AGP Super 2-Speed...
Andis master clippers lose power
Oil the blades and then adjust them. You will need to add oil while grooming from time to time and then clean & oil them again when finished.
Sep 23, 2012 | Andis Improved Master Clipper/Trimmer...
Why my andis outliner not cutting
Try cleaning the head cutter below the main stem. Remove screws and clean old hairs in there, also lubricate.
Thanks
Jun 13, 2011 | Andis 04603 Hair Trimmer
When i cut hair my andis master clipper seems to get stuck while cutting hair causing me to take longer with the fade how do i go about fixing it to where it doesnt get stuck in hair & by the way im...
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
Jun 19, 2010 | Andis 01690 Hair Trimmer
How do I adjust the blades or sharpen blades on a Andis T-Outliner trimmer? I have some older blades that work farely better then my newer blades that are dull if you ask me. Is there some way to manuver...
Clipper blade sharpeners are availale but the cost of these typically start at about $300 and go as high as several thousand dollars. This makes it unaffordable for home use.
For affordable, professional clipper blade sharpening, I suggest you contact the folks at clipperparts.com
Your clipper moves at just one speed. There is no way to 'speed it up' if it is working correctly.
Feb 05, 2010 | Andis 04710 Beard Trimmer
Misses hair when cutting
You probably need a new blade drive, which is easily replaced yourself, if you are so inclined.
Apr 20, 2009 | Andis 01690 Hair Trimmer
I have a mastercraft mitre saw. The blade blocks midway when I am
The picture I could get only shows one side. From my experience, these guards operate using leverage, where a little motion results in a lot of movement to the guard. That means a little damage or wear in the linkage can make a big difference. A bushing may have shattered, or a pivot hole may be worn out. Reviews of this machine mention dust not going into the bag. Make sure dust is not jamming the guard works. Take care, having to move a guard while the blade is spinning is scary.
Mar 28, 2009 | Dewalt Mitre Saw Workstation
Andis pm-3 dog clipper won't cut anymore!
I have had this same problem!  I bought new blades, sharpened old ones, and nothing worked.  Finally, I went to an authorized service center and they couldn't figure it out.  Then the tech. pressed on the blade (the outside bottom one) and it cut!  When you remove the blades with the 2 big screws, there are 2 more smaller screws inside under the smaller blade.  One of those was not screwed in tightly.  That was all it was!  I guess they jiggle loose.  I hope this helps!
peony
Mar 02, 2009 | Andis ProMotor PM-3 Hair Trimmer
Grinder problem
* The base plate can be tilted to make angled cuts. Most saws adjust from 90 degrees to slightly less than 45 degrees, making it possible to cut bevelled ends on boards for corning attachments, hip-roof rafter cuts, and even miters. Most saws are equipped with a thumbscrew or lever to loosen the bolt which keeps the saw blade on the correct angle for the cut you are making, located on the front of the saw. Some are also equipped with a scale which indicates the blade angle, from '0' (90 degrees, or square to the board surface) to 45 degrees. * The blade can be set to the depth required for individual cuts, from less than 1/8 inch to the full depth the blade is capable of penetrating. The lever or thumbscrew which locks the base plate at the desired height is usually located at the rear of the motor on the left side. * Many circular saws are equipped with a ripping fence, to guide the blade as you make a rip cut along the edge of a board, giving you a straighter, parallel cut. * Dust ejector. A few newer saws are equipped with a dust ejector to blow the sawdust away from the operator's face and from the mark where the cut is being made. * Laser tracking light. Some newer saws are equipped with a laser that projects a bright, red line down the path of the blade travel. These can also be purchased to retrofit on older units that are not factory equipped with them. * Blade guard. This should be considered a essential safety feature on any saw, and has two parts, the fixed guard over the top of the blade, and the floating guard, which rolls out of the way as the saw is pushed into the work piece. Some have a handle so the blade guard can manually be lifted for plunge cutting or easier viewing of the cutting mark.
Aug 27, 2008 | Speed CGW ABRASIVES 35587 "24-GRIT" HIGH...
Andis 01690 Hair Trimmer Logo
1,384 people viewed this question
Top Andis Health & Beauty Experts
Bruce Showalter
shaveroutlet.com
shaveroutlet.com
gggg
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
