Question about Jenn-Air JMW9527C Stainless Steel Electric Double Oven
Jenn-air jmw9527 When you turn oven on The display reads not available detected a fault that affect the performance. and in the upper right hand corner of display it shows lclc I assume this is a fault code. I hope someone can help. Hubb!
  • Anonymous Dec 31, 2007
    have the same problem. it's new year's eve.
SOURCE:
  • 10 Answers
SOURCE: Electrical Jenn Air Oven control panel ..
you need to troubleshoot the unit and make sure it is getting the right voltage out of the power supply. i think there are multiple voltages going to this unit. I cant find out what is supposed to be supplied to the unit to truoble shoot it
Posted on Dec 01, 2007
SOURCE: Problems with Jenn-Air Electric Double-Wall Oven
Try changing the clock assembly --
http://www.partselect.com/ModelFrames.aspx?ModelID=221346&ModelNum=WW30430P&mfgModelNum=&ManufactureID=1&Selected=51238&Position=1&mfg=Maytag&Type=&Mark=1
here is a link to the diagram.
PS120923
Electronic Clock Assembly (Series 10)
Help with series numbers
here is the part number.
Posted on Feb 17, 2008
  • 1314 Answers
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
Posted on Feb 19, 2008
SOURCE: jenn air oven display
the digital display on my jenn-air oven, model jjw9527c...has gone completely out. i am very efficient in wiring and electronics and would have no problem fixing it myself, just not sure which parts i need to order. Please return this with a solution, holiday season is very close.....thank u
Posted on Sep 11, 2008
eagle338
  • 4889 Answers
SOURCE: F2 fault, continuous fan after clean cycle for Jenn-Air electric convection wall oven
The "F2" means the oven control senses runaway temperature. The cause of the problem could be the oven sensor, the oven sensor wire harness or the power relay board.
PS:please disconnect your oven from power supply completely before continuing.
Open the control panel and measure the oven sensor resistance at the control board. It suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong do the same test at the oven sensor connection (where the sensor wires goes through the back panel).
If the reading is still wrong - replace the oven sensor.
If the reading is correct, check the wire harness and the connector itself (it's better to eliminate the plastic plug and hardwire the oven sensor).
If there is nothing wrong then the power relay board has to be replaced.
Posted on Nov 07, 2008
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
Range has a very dim display
I have a Jenn-Air double wall oven with a very dim display light. Replaced c3 capacitor 68uf 35w - with a 100uf 50w cost $1.60 closes size available at Radio Shack and works good as new. Requires soldering onto the circuit board. I price a replacement part for $276.00.
Mar 19, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
MY JENN-AIR MODEL #WW2460B WALL OVEN DOES NOT DISPLAY THE CLOCK/TIMER. IT STOPPED WORKING DURING A SELF CLEAN CYCLE. IS THERE A WAY I CAN ORDER THE PART TO REPLACE IT MYSELF AND ARE THERE WIRING SKEMATICS...
There is a high limit thermostat that will cut all the power to the upper oven elements. Their is a wiring diagram in this link http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Wall-oven-Parts/Model-WW2460B/1266/0125300?pathTaken=&prst=0&shdMod=WW2460B
when clicking on it,it will say not avaliable. A trick i have found is to open that link and then using your computer tools select the maximum zoom i use IE set to 400% and its pretty ledegable.
Gene
Aug 11, 2011 | Jenn-Air Ovens
I had to pull my oven out of the wall and ever since I did that, I get a message that says "Feature Not Available" on any button I hit. Is there a reset button or something?
It's an error code that will not go away until a technician resets it. Quote straight from the manual :
"The oven may detect a fault during programming or during operation. If a fault is
detected, the message "Fault detected - press power to clear" or "Fault detected -
press enter to try again" may appear. Follow directions in the display. If the fault
reappears or does not clear, call an authorized servicer or the toll-free number in the
display.
If the same operation is attempted before having the wall oven repaired, the message
"Feature not available" will appear. The feature will remain inoperable until service
is obtained":
Mar 15, 2011 | Jenn-Air 30 in. Pro-Style Electric Single...
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Fault has been detected
I'm afraid I can't help you but if you go to www.jennair.com and sellect support they should be able to.
Jun 21, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Fault code F1 on a Jenn Air WM2780. Upper oven
Usually this is a problem with the control board. The board can be repaired at www.fixyourboard.com.
May 21, 2010 | Jenn-Air JJW8230D Electric Double Oven
Jenn-air w156, displays f1 fault code. how do i
This is a Defective touch pad or membrane
Replace touch pad or membrane (this problem is usually the touch pad)
Jun 17, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
JJW9830DDS
THE SOLUTION WAS TO CALL FOR SERVICE. IF YOU CONTINUE TO USE THE UPPER OVEN , THEN THERE IS A POSSIBILTY IT CAN CAUSE A FIRE IF THE BLOWER IS NOT WORKING. THE COST OF THE REPAIR FOR REPLACING THE BLOWER WAS ABOUT $390.00. THEY NEED TO REMOVE THE OVEN FROM THE WALL CAVITY TO PERFORM THE REPAIR.
Mar 21, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JMW9527C Stainless Steel Electric Double Oven Logo
203 people viewed this question
Top Jenn-Air Ovens Experts
Craig Butler
Craig Butler
Sal De
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
