Question about Sony KV-36FS100 36" TV
Won't Power-On Mfr date Oct '02, Set will not power-on. No lightning storm or power surge. Surge protector working fine. Just not getting power...any suggestions. Is there a re-set button or fuse that can be checked or changed? Appreciate any assistance. Thanks.
  • Golfer4life Aug 19, 2007
    You're awesome!! Removed the back cover, checked the 6.3Amp 125Volt fuse...it was bad, replaced it...I'm back in action!!
    Problem Solver:
  • 18 Answers
Do you have a VOM meter? Unplug the set and open the back, the fuse should be easy to find "small glass cylinder with a metel cap on each end. Test it for continuity. If it tests good or shorts again after replaceing then there is a lot of other things that can be wrong. Let us know. If you replace it it is important to use the same exact value which should be written on the board next to it also NEVER jump it with a wire! Hope this helps. Don
Posted on Aug 16, 2007
SOURCE:
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
Stopped working after a storm
Did you have a power surge after a loss of power? If so your TV is ruined from the surge. In the future use a surge protector if don't already.
Aug 20, 2016 | Televison & Video
Titan Troubleshooting
Check for small fuse on circuit board:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Water heater circuit boards are NOT protected from surge. And reset button does not protect from surge. Nearby lightning can put out any household appliance, especially since more of these things are electronic instead of mechanical.
Install single-use whole house surge protector and replace it after each surge event instead of replacing appliances.
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
The quickest solution for tankless is to replace whole thing with more reliable tank-type electric heater for $275 from local box store.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 18, 2013 | Water Heaters
Lightning struck my Bravia
your tv is shot ,im sorry to say that but its burnt
Jul 29, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
After a lightning storm my bosch single 30" wall oven displayed an F03 err. I turned the power supply off at the breaker for one minute as directed by the oven's manual. This action did not...
Find out what the F03 error is for and then check out the appropriate area. If there was a strike of surge the most likely place to look for damage is the area where the electricity first enters into the device.
Sep 07, 2017 | Bosch HBL 5036 Electric Single Oven
Lightning storm & power went out for about two seconds. PC plugged into surge protector but would not go back on. Found that surge protector blew and was no good. Got another and plugged all back in...
Your reasoning about the switch mode power supply being damaged is probably right.
Bear in mind that this power supply may not be the only thing that may be damaged in your computer.
You won't know for sure until you borrow a power supply and install it into your computer to see if it will work again.
Jun 18, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
I have a [email protected] Model No. E5908, 5.8GHz Corded/Cordless Telephone/Answering System that has always worked perfectly until a bad lightning storm hit a couple of days ago which caused the power to go off. The...
I hate to be the bearer of bad news, but there is no reset on the phone system, and it's a near certainty that a power surge during the storm "fried" the sensitive circuitry in your phone. The same thing happened to me a couple of years ago and I ended up replacing my phone system. A corded phone in the house at the same time lost its ringer during our storm. To this day it still works fine, but will not ring. While you cannot save your present equipment, it's possible to protect your replacement by installing a phone line surge protector (available at just about any store that sells phones or computers) and a whole house surge protector that you install at the main outside breaker box (you'll need to search the web for that one. Look for a SYCOM surge protector).
Mar 30, 2011 | AT&T Lands Phones
After my house was it by lightning my Onkyo
If your receiver was connected to any power source and that power source was not a surge protector strip there may be damage to the receiver as lighting travels. Another thing to consider is the fact that many people will put their equipment on surge protectors but the cable is still connected to the TV etc...This is just another avenue for the lightning to get into the home and blow up your system. I always disconnect any cable from my computer and TV. The power source from the wall is also unplugged when there is a storm just to be sure. Surge protectors are limited in their use as well. I don't believe they can take too many lightning hits. It is best to change them out.
Jul 18, 2009 | Onkyo HTR500 Receiver
Sony KV-36FS100 36" TV Logo
124 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
