Question about Cyberhome CH-DVD 300 DVD Player
Blank Screen I was trying to configure the DVD with the receiver but when I changed (in the DVD SetUp) the Video for PScan the CyberHome Blue Screen disapeared and a Blank Screen(Black Screen) apeared. Since that I can´t access the Set up again to change it back. I also tried the Jack Dan Suggestion "putting it on standby, turning on and then opening the disc case and pressing stop for 5 secs. It didnt work. I just need to acces the Set Up menu to change it back or reset to the factory default configuration. Please ! Help ! Atc. DeniAqui(Brazil)
  • DeniAqui Aug 16, 2007
    I forgot to say that the DVD model is CyberHome CH-DVD 300
    Problem Solver:
  • 13 Answers
There is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds (some solutions say 20 seconds).
Posted on Oct 27, 2008
Thats a great trick to fix this problem.Thank you much for letting me change to factory settings without even knowing what I was changing. That was easy and very helpful.
Posted on Sep 08, 2007
Thanks a lot!!! I had the same problem and I tried everything else and nothing worked. But I tried your little trick and it did the job! Again THANKS!
Posted on Aug 31, 2007
Try this, it worked for me. Power On with no disc in machine. Press Setup, Press the green right arrow button 3 times, Press Enter, Press the green down arrow button 4 times, Press Enter It should then reset to factory default settings.
Posted on Aug 28, 2007
  • 102 Answers
Leave it un-plugged for a while to reset it.
Posted on Aug 16, 2007
2 Suggested Answers
SOURCE:
SOURCE: CH-DVD 300 Blank Screen
This is almost the same problem for me...Please provide a solution
Posted on Sep 05, 2007
Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
May 27, 2008 | Cyberhome CH-DVD 300 DVD Player
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
Pscan interlace screen gone blank
hi plz go to setting and reset ur fectory its code is 000000.
Mar 09, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Split Screen
Go into SETUP
GENERAL SETUP PAGE
Go to VIDEO OUTPUT (can't see through error message, but it is the second one down - If you are on the right one, you will see S-Video, YUV Interlace and YUV Progress. as choices)
Change setting from YUV Progress to YUV Interlace
Mine was set on YUV Progress. and when I changed it, the problem disappeared.
Mar 06, 2008 | RCA DRC200N
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
Removal of pscan option on dvd player
Dear friend,
Press and hold the stop button on the player front panel more than 5 sec. player will be resetting
Oct 25, 2007 | Cyberhome CH-DVD 300 DVD Player
Aug 16, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
No video
If you select Progressive Scan and your television doesn?t support it, you may end up with a blank screen and be unable to view the menu in order to fix it. If that happens, fix it by turning the DVD player off then back on. Open the disc tray, then press and hold the STOP button for five seconds.
Jul 24, 2007 | Cyberhome CH-DVD 300 DVD Player
Stuck on either PScan or PAL; can i reset the whole darn player?
To reset Cyberhomes DVD players. Take the dvd out close the tray. then press and hold stop for five seconds.
Aug 04, 2006 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
326 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
