Question about Hitachi 28LD5200 28 in. HDTV-Ready LCD Television
Screen problems Hi, Since two days I have been having problems with my tv. Whenever I turn the tv on, the screen is one big mess of vertical lines, the color of the lines depending on the picture or program that is on the screen. No matter if I turn the dvd player or my wii on, the screen stays the same. The sound though, works perfect. However two days ago when it first appeared I only had to turn the tv off and on in order to solve the problem. Then a day later this wouldn´t work anymore and I had to disconnect and connect my wii in order to get the screen working again. However yesterday a couple of men tried to configure our satelite receiver and since that moment the screen has been like this. We've tried removing or changing the antenna, the wii and the scart cables yet nothing works. I don´t think the screen is broken because when I press the menu or teletext button they show up perfectly without the lines. Please help me find a solution. Regards, Cecilia
    Genius:
  • 1,153 Answers
Sounds like you have caps going bad in video circuit. This will need repair from export. If tv is in warranty, then send back.
Posted on Aug 16, 2007
SOURCE:
Whenever I turn on the tv or watch a movie there is a thin blue vertical line on the left side of the screen that doesn't go away
the problem which is in vertical section on board it is an repairable the filterization capcitor problem
Nov 09, 2010 | Samsung LN32C350 32 in. TV
There is a very thin vertical red line on my screen that has appeared this morning and is is there whenever the screen is on, no matter what program I am in.
That problem is called Vertical Problem in your TV.It might be cold solder or loose connection of board in vertical section.Need for resolder or if not work after resoldering.The vertical ic is the problem it is deffective.
Oct 06, 2010 | Acer X233H 23 in. LCD TV
COLOUR ON MY TV IS MESSED UP.
palsonic tv is green and blue
Jan 11, 2009 | Televison & Video
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Audio is fine, but video will off after 5min ON time
Good Day, howac506;
The most common problem for your 1991 TV is the vertical out put IC (IC) part number 272p239040.
I hope this was helpful.
Good Luck again, big IRISH.
Aug 04, 2008 | Televison & Video
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Dec 20, 2007 | JVC AV-27730 27" TV
JVC 31" TV Vertical Screen Jumping
I've heard this is could be a cold solder joint and am looking for advice on which IC to re-solder. 1 whatever you have heard is correct as whenever you smacked the lelt side it works fine. 2 you will have to check loose contact in vertical section. your vertical ic might be located at the left side of the tv. 3 check any connector is loose near vertival section. 4 any preset is loose in vertical section. it is a simple problem if you are not technical person please get it done by tech person. as your tv is old & if it is done by tech person tell him to replace all elrctrolytic capacitors in vertical section. good luck.
Sep 20, 2007 | Televison & Video
Screen Size is Too Big
There should be a vertical height adjustment control potentiometer near the vertical output IC on the right side of the PC board near the front section of the TV that can be adjusted to shrink the picture vertically. Be careful not to short anything out or getting yourself shocked in the process if you decide to try to adjust it yourself. Good luck. This chassis has also been known to have bad solder connections in that area also, so don't man-handle the printed circuit board roughly.
May 23, 2007 | Zenith D32D51 32" TV
Hitachi 28LD5200 28 in. HDTV-Ready LCD Television Logo
123 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
