Question about Samsung CLP 300 Laser Printer
Printing stops half-way
Hi, this is my first post =) here is the time when someone in my family is panicking because of a deadline due in this afternoon, and the CLP-300 keeps stopping the printing half way through the document, on screen on the laptop it show that it has finished loading, but the printing just keeps stopping after printing out one page, with the red light on (not flashing), and then nothing happens again until i press the stop button... what's wrong with it? o.o
  • cthulhu34 Dec 08, 2007
    Almost the same problem but for this instant i have selected every type of paper and it still jams,it's almost like the printer isn't strong enough to grip the paper.I can get one or two printed if i puch the paper as its trying to grip it but this is ridiculous,i am not going back to prehistoric age.Feels like a am using a hand scanner to scan 1000 atlas.:(.Any suggestions?Its still under warranty so I cannot take it apart.
I had exactly the same problem - seemed to fail to pick up the sheet. I tried reversing the rubber pickup, but although I think this would work in some cases, it didn't work for me. What DID work was SO simple:
Take a piece of paper and fold it in half a few times, then tape it to the bottom of the paper tray, so that when in place, it will be under the pickup roller at the back. Now load with paper. The paper will be slightly raised at the back (below the pick up roller) and the increased pressure will magically make it work like new! Don't obstruct the paper-out detection slot - otherwise it won't know when it is out of paper.
Posted on Mar 11, 2008
I have had the same problem for months and it drove me mad!
Today I found the solution!
It is true that the printer jams all the time because of its incapability to get a grip on the paper.
If you look over the paper tray inside the machine and you start printing, just before it jams you will see some sort of rotating device, trying to pick up the paper for transportation. This little piece seems to be the problem, because you will see that it is unable to lift the paper.
The problem is, that the surface of this part isn't rough enough.
It used to be, when you just bought it, but over a certain time it got too smooth.
Here is what I did;
I took out the paper tray, so that the rotating device was clear to work on.
With a little sharp knife I started to scrape and make little cuts on the surface too make it rough again. And guess what, it worked!
I have just printed thirty pages without problems, Yes!!!!!!
I guess that the problem will return when the surface of that rotating device gets too smooth again, but now you know what to do.
The worst thing is that in the end it feels even very logic.
Why didn't I think of this much sooner?
Anyway I hope this will work for you as well, any many others....
good luck!
R.
Posted on Dec 29, 2007
Working Fix No Parts Required!
I had the same problem. I initailly managed with it by helping 1 page at a time through. Lost my temper with it today and although it is under warranty got my screwdriver out. if you pull the paper tray out you can see a rubber pickup roller at the back, it is easier to see if you flip the printer upside down. I am not saying this is the best way of repairing but worked for me and think it will resolve this issue in most cases. Fistly make sure you make a note of where everything goes (screws etc.) as you go along.
1. Remove the top cover (two screws under the front door)
2. Remove the two sides and back door.(sides first 1 screw on one side)
3. remove all screws on the metal plate at the bottom of the back side. A black plastic guide will drop off the back but it is easy to get back on. If not pull it off for now.
4. Rest the printer on its front if youve not already, you should now be able to bend the metal plate towards the left hand side enough to access the rubber pickup roller.(maybe an easier way but this worked for me).
5. Carefully unclip and slide the roller out(not the metal bar just the white bit with a black band on). This is quite tight take a minute to see how it clips in so you know how to put it back.
6. You will probably see that the section of the rubber band that has been in use is white/grey. Rotate the band so the unused section is where the white bit was (hope that makes sense).
7. Put everything back as it was and its as good as having a new pickup roller.
Hope this helps
Posted on Nov 25, 2007
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 171 Answers
IT SEEMS SONETHING (BIT OF PAPER ETC) IS TUCK INSIDE THE FUSING UNIT ON THE EXIT SIDE.. YOYU NEED TO CLEAR THE JAM. HAPPY PRINTING OMNIPRESENT
Posted on Oct 02, 2007
SOURCE:
RX650
any lights flashing when it stops
Jan 11, 2008 | Epson Stylus RX650 All-In-One Printer
Where did i get password and username to fill on funza form.i tried several times
Hello, Khayelihle -
Let me guess. You reside in South Africa and are asking about the Funza Lushaka Bursary Programme.
I am in the USA.
Visit the Funza website:
http://www.funzalushaka.doe.gov.za/
I suggest you use your telephone and talk with someone in the South Africa Department of Basic Education. This is the telephone number: 0800 202 933
I see the Funza application deadline is 12 Jan 2018. Now, you have learned one of the challenges of waiting until the deadline.
Best wishes.
Jan 11, 2018 | Financial aid
I am having the hardest time ever trying to put this machine together and need someone to help me with step by step instructions. I am on a deadline and this needs to be finished today, classes start next...
hi there
if possibole contact me i can send instruction manual for this machine , also if you need more help please email me [email protected] or by MSN messengr .
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
Jan 22, 2011 | Juki DDL-8700
Closed Captioning stopped working.
due to the new digital change alot of sets like your are being effected with similar problems such as guide and time issues. not sure if it will fix itself after the deadline
Jun 05, 2009 | Sanyo DS20425 20" TV
Printer keeps showing a stop job with exclamation point
Do you have a Mac OS X?
Maybe you just need to reinstall the driver. Download it through the following link:
http://www.techspot.com/drivers/driver/file/information/7584/
Let me know if it does not work and tell me what OS version you are using. Click on the Apple menu and select About This Mac to get the version.
Thanks.
Apr 15, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
New ink is not printing
make sure the paper is off the ink cartridges
Jul 29, 2008 | Canon i9900 InkJet Photo Printer
Kyocera FS1010 first page only half printed
I found this solution. Worked a treat. I took the printer apart and applied felts to the solenoids (the felt normally used for the bottom of cup coasters).
See the Success post in this thread...
http://www.copytechnet.com/forums/kyocera/15980-kyocera-fs1010-delayed-printing-1st-page-2.html#post55451
This manual helped too...
http://www.freeprintermanuals.com/PM/Kyocera%20FS-1010%20Parts%20Manual.pdf
This is the post...
Success
A solution has been found. Thank you to Steveauh (Townsville)
Kyocera in their wisdom have used a foam insulator on the 3 solenoids that disintegrates over time regardless of use.
  1. Open the right side of the printer
  2. Disconnect all connections to engine board
  3. Remove engine board
  4. Remove plastic guard (white)
  5. remove all 3 solenoids
  6. Replace all pads on the solenoids that come up against stops
    Registration Solenoid has 2 pads (1 against the solenoid frame and the other on a stop arm, the others just the frame pad)
  7. Keep thickness to around .4 - .5mm Too thick on register arm will cause early printing.
  8. Reassemble
And that is it. The arms were being magnetically delayed due the metallic contact. It seems to be a regular problem in this chassis FS1000 to FS1030.
Jun 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Samsung CLP 300 Laser Printer Logo
301 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
