Question about LG Flatron L1710S 17" LCD Monitor
No image on screen when boot up computer
When I boot up my computer & turn monitor on the indicator light on the monitor turns from inital green colour to amber and I only get an on screen message of "power saving mode". There is no image of the computer booting up or XP starting, just black screen. It was working fine one minute and then after shuting down and then re-booting not long after I encountered the problem.
  • Anonymous Jan 04, 2008
    I have the same problem with the LG Flatron L1710S, would be great if this can fixed
    Thanks
  • fabians Jun 10, 2008
    Screen flashed then goes off. if you power down and power up then the same thing happens
  • 109 Answers
Check vga cable! check also video card on the pc!
Posted on Jun 01, 2008
    New Friend:
  • 3 Answers
Sometimes an old driver for this monitor will mistakenly believe it can display a higher resolution - and so it goes out of range when things autorun.
Step one - if you can, connect to another monitor, or your tv, with both old and new hardware installed and simply download and install the new driver.
If that doesn't work, boot into safe mode (it naturally sets a lower resolution).
And when all else fails.... Best trick I've found is to clear your CMOS (reset your BIOS) and, oddly, plug in a different keyboard to a different port and hold delete when you boot. If you need to repeat, change keyboards again. (make sure you hold the delete key down before you even plug the computer back in and it should work fine.) Also, for those unfamiliar with resetting their BIOS, write down your settings first, or ask a friend.
G'luck! Took me some research but I eventually made mine behave. :)
Posted on Apr 24, 2012
SOURCE:
Hello, I own a Dell LCD Monitor, when I boot up the computer the monitor stays black. I see the desktop image for half a second, but very faintly. The power light is solid green and remains so. I have...
The fault could be a faulty inverter board that supplies high voltage to the CCFL lamp or the CCFL lamp is faulty. The CCFL lamp is a mini fluro lamp that provides the back lighting for the screen.
Jul 16, 2012 | Computers & Internet
When i turn it on it only appears only a second , my monitor turn black
Hello Chelleydiao, hi, its either you have a CPU problem or the monitor itself. Check or use another monitor to see if the problem is fix. you see an blank monitor can also be caused by the CPU if it fails to boot. the aid the checking, do you see any orange light on the monitor? or any indication.... the led light on the screen in summary: green or blue means there is power and the CPU boots up. if orange the CPU fails to boot, if there are no lights on the Monitor panels, there are problems on the monitor. check these first....I need a much detail description.
Dec 18, 2010 | AOC Monitor
My acer flat screen monitor will not come on. My mac mini starts up, but the screen stays dark. Last week, it was staying dark after the computer went to sleep; I couldn't "wake it up." After a few...
I will assume that you have checked out the power cables and external cables. If this is the case you will usually notice an indicator light from your monitor. Universally it is yellow or orange when it has power, then turns green when it detects input from your computer. If the Led light doesn't turn green even when your laptop is already booted, your culprits would be your iMac's video controller or your monitor's input cables.
Jan 29, 2018 | Acer AL1715 17" LCD Monitor
Image for first 3 secs... light still on green
correodemie, Your ACER AL2016 will need to have it's "switch-mode-power-supply/CCFL inverter supply" trouble shooted and repaired. DIY repair cost less than $30. Out of warranty service $35 to $75, more if circuit board replaced. Read my and other techs FIXYA profiles to discover all the options you have for your BLACK screen symptom. Follow the links to other web sites for even more useful info. DO THAT before you do anything else. 12fixlouie
Feb 03, 2010 | Acer AL2016 W 20" TFT LCD Monitor
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
Hanns g JC199D will not turn on, comp is on, try to turn monitor
no signal indicates a couple things... i suspect your computer isn't even booting up. reboot the computer while tapping the F8 key.... you should see writing on the screen... boot to safe mode. after it sucessfully boots up... reboot again... should be fine.
Robert
also is that an add on video card ?
Dec 18, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Monitor
hi the problem isnt in the screen its in your configuration in the bios or your OS go insdie the bios menu and choose the default option and save it good luck
Apr 02, 2006 | NEC LCD1915X (Black) 19 in. Flat Panel LCD...
LG Flatron L1710S 17" LCD Monitor Logo
329 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
