Question about SanDisk Sansa e200 MP3 Player
Sandisk Sansa e250
When iam on the mp3 i go to videos and select 1 it frezzes up then i have to reset then when i try taking them off the mp3 freezzes help me
  • lil_firef609 Jan 09, 2009
    I dont have a volume + button thing. mines the sansa e250 2gb its messed up i just want to reset the thing nd none of these work cos i dont have a volume up button i have this raised thing you turn to turn the volume up
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
I have Nokia 5130. Iam unable to play Youtube videos. Therefore I have downloaded "YouTube_Web.jar" from www.getjar.com . Trying to Install it , but could not install it. Could you please resolve my issue?...
Use http://www.downloadvideos-convert.com/download-videos-music
1. Download Video Download Studio, install it.
2. Go to the interface, you can download (Automatic capture) the YouTube video there directly. Tab Download to Convert, you can also click "Add" button to upload the videos from computer. You can also edit video by trim and crop functions.
3. After the video display on the Video Download Studio, click "Profile" and choose "General audio", then select an MP3 format. Set destination file, clicking Convert button to complete the task.
Not only convert video to MP3, but also support batch conversion. Safe and easy to operate. No Viruses, No Spyware, No Adware. Do not hesitate. Have a try!
May 10, 2010 | Nokia 5130 Cellular Phone
My transcend T.sonic 840 cannot boot it hangs on transcend when power on.please i need a solution.
1.download the appropriate firmware from here 2.press and hold reset button for 2 seconds 3.run the firmware updater 4.press and hold "volume -" button while connecting to system. 5.the updater will detect the player and it will upgrade the firmware
Sep 07, 2009 | Transcend T-Sonic 840 MP3 Player
Ipod frezzes up & won't shut off any clues on how to fix??
To reset the ipod, move the hold switch on and then off again, then press and hold the select and menu buttons. It should reset in 6-10 seconds. As far as fixing it to keep it from resetting, you need to format the ipod which will delete all the music on it. To format you plug it into itunes and under the properties for the ipod there should be an option to format the ipod.
Jul 20, 2009 | Apple iPod U2 Special Edition MP3 Player
Mp3
ok dude, yu might need to reset it, call sandisc at 1-866-726-3475
they will tell ya how, you can contact me at www.freewebs.com/mixedjujitsu if problem persists.
Dec 27, 2008 | SanDisk Sansa m240 MP3 Player
I NEED TO TAKE EVERYTHING OFF MY MP3 PLAYER(8.0 gb)
its new and its frezzing.dosent turn on unless is connecte to computer
Nov 28, 2008 | SanDisk Sansa e250 MP3 Player
Frezzes wen it just loads into a game
Hard Reset procedure for the PS3 (as instructed by Sony CS).
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hopefully this will solve your freezing problems.
May 12, 2008 | Sony Playstation 3 (PS3) Console
Mp4
Sorry but Your ps2 wont support Mp4's .But you can use winamp to convert your mp4's to mp3's
Nov 26, 2007 | Sony PlayStation 2 (PS2) Console
My ilo player is not responding well.
Take the battery out for at least 40 min. This resets the player. If not, call c/s 254-224-0222. they will email you the firmware to reinstall.
Jul 03, 2007 | iLO (2 GB) MP3 Player
SanDisk Sansa e200 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
