SOURCE: Error E03 -
I tried Tapping on side of Camcorder and I worked, after 2 or three times while message appeared.
SOURCE: Safeguard Mode 03
E03 is a mechanical fault on the mechanism,it may be the reel pulleys are bent and need to be straightened.If this is not a solution, take it to JVC agents,the mechanism is likely to be damaged if not repaired by the agents.
SOURCE: JVC mini GR-D23EK Unit in SAFEGUARD mode E03 how to correct it
Hello. What I've found is that in dealing with the error codes your choices are very limited. You can try removing the battery and power supply for a while. This might clear the code, however, failing at that you'll be forced to send in the unit for repair--you are absolutely not alone in getting this type of problem--definitely get a quote first and keep "do I want to replace this unit" in the back of your mind....This is a JVC problem.---Rick
