Question about Indesit W 123 Front Load Washer
Error code f-02
Indesit front loader showing error code f-02.have changed the brushes as suggested but its still showing the same error code HELP!!!!
  • 1 more comment
  • davymac Aug 16, 2007
    no motor not spinning
    no the motor dos not spin but it is trying
    motor has blown.but hey thanks for trying mate
  • 641 Answers
Does the motor spins ?
Posted on Aug 16, 2007
  • Dov Dror Aug 16, 2007
    Check with a multi-meter motor's field resistance and see whether they are OK.
    In case they are OK, replace the capacitor.
SOURCE:
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 fault code on indesit we16 washing machine
According to info on a similar site to this, it means motor jammed/tacho faulty or detatched
Mar 23, 2008 | Washing Machines
Error code on washing machie
The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too.
Jan 03, 2008 | Indesit W 123 Front Load Washer
Indesit we14
Hi l have a indesir WIE147 that keeps on flashing F 01 repair man came changed module and next day same thing happened again HELP PLEASE
Nov 13, 2007 | Indesit W 123 Front Load Washer
Showing error code f-o2 HELP!!!
f-02 should be your carbon brushes which are situated on your motor they are plastic with 1 wire going into each 1 there is 2,1 on either side of your motor
Aug 14, 2007 | Indesit W 123 Front Load Washer
Error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Aug 11, 2007 | Indesit W 123 Front Load Washer
Washing machine not spinning
Check your brushes in the motor. Have a good torch with you. You will see the brush holders and the brush sticking out. With a small screw driver lift the brushes back up into the holder to see if you have any travel.? A front loader can cut out a set off brushes about every five years.
Nov 30, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
517 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
