Motorcycles Logo
A
Anonymous Posted on May 27, 2013
Harley evo ignition
No spark. good coil voltage
5 Related Answers
Anonymous
  • 149 Answers
  • Posted on Jan 31, 2009
SOURCE: front clyinder not firing ignition coil is good & spark plug &cap
Swap the caps around from the rear it the fault changes replace the cap, you can also test the cap with a multi meter it should read around 5k ohms or some of them may be 10K look on the cap..
Anonymous
  • 216 Answers
  • Posted on Apr 29, 2009
SOURCE: need diagram for harley evo ignition diagram
join www.chopperweb.net/ ,,, its free ,,,, they have a searchable database of all the wiring diagrams you'll need plus the members help when u run into problems
Anonymous
  • 1392 Answers
  • Posted on Jul 25, 2009
SOURCE: Low voltage at coil on 1983 DR 250
Check for a short, or partially broken wire between CDI and coil. If your wiring is goodbetween there, check between CDI and pick up.
Anonymous
  • 26 Answers
  • Posted on Aug 23, 2009
SOURCE: motorcycle started backfiring when giving
Why was the pick-up melted - are the problems related, perhaps, perhaps not. I think it likely to be a broken coil causing the misfire, but as laways check spark plugs, leads, fuel delivery, first before spending cash. Try and borrow a coil from another similar bike to see if it works, if not it is down to tracing the whole ignition system and checking every component for breaks, splits, bad contacts, etc
Testimonial: "excellent just what i suspected"
Anonymous
  • 4565 Answers
  • Posted on Sep 21, 2010
SOURCE: 79 harley ironhead 1000cc xlh no spark from coil
It sounds like your sensor in the timer cavity on the right side of the engine is bad. Disconnect the blue wire from the coil. Take a spark plug out of the engine, put it back in the spark plug wire, and lay it on the head. Turn the switch on and momentarily touch the blue wire to the coil. When you take the wire off of the coil, you should see a spark at the plug. The purpose of the sensor in the timer cavity is to stop the flow of current in the coil and initiate a spark.
Good Luck
STeve
1helpful
84-92 hd evo wont fire,have power to coils,and coil shoots one spark after turning off ignition
You have lost either an ignition unit or the timing sensor down in the timer cavity on the engine. I don't know of any reliable way to test them.
Good Luck
Steve
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
