How i find cos theta 50 in my scientific calculator
To calculate the Cosine of an angle, you first make sure that the angle unit on your calculator is set to the correct one (degree, or radian). After that it is all simple. Enter the angle value (50 degrees) then press the [COS] key. If you get an error then press the COS key followed by the angle value then press =.
Note if your calculator display Cos ( , with a left parenthesis, then you have to press COS first followed by the angle value and possibly the right parenthesis.
Note. The theta here is of no relevance.
SOURCE: how to draw f(x,y) =x^2+y^2-2x
Press [MENU]. Highlight the [GRAPH] icon and press [EXE]. Press [F3:Type] then [F2: r=]. Enter you expression as 1+ cos(theta). If there are any functions Y=, delete them by highlighting each one and pressing [F2:Del][F1:Yes].
Press [F6:Draw]Your cardioid is drawn on the screen. This type of graph r=f(theta) is a polar graph.
Hope it helps.
SOURCE: FX-55 Calculator: how do I clear my casio scientific calculator from...
press the "MODE" button 3 times and then press 3 ..., now this is normal mode
SOURCE: For get the life of
When using trigonometric functions (cos, sin, tan) and their inverses (arccos, arcsin, arctan) one must be aware that the result will depend on the default angle unit : radian, degree, or grad.
Apparently you are working with the degree as the angle unit, so you must configure the calculator for that unit. (See screen capture below)
Press [SHIFT][MODE] [3:Deg]
