Few years ago I installed an Excel based application on Acer Desktop which needs an activation code. For some reason they the application needs new activation code.This code is generated based on the 16 digit computer code.The computer code they are sending me now is different from the first code.They're saying that the computer is the same.Is it possible the 16 digit computer code to be somehow changed?
SOURCE: sdram capacity
its that 512 mb total capacity for your computer memory?? if so read this:
To find the total amount of RAM that can be added , subtract the amount of RAM currently in the computer from the maximum amount of memory the computer can hold. For example, a computer has 256 MB of RAM. If the maximum amount of memory the computer can hold is 512 MB, then 256 MB is the amount of RAM that can be added. this info from the HP website , to find out more , go to http://www.hp.com/support , enter the model number , and look for more information about your computer specs, hope this helps , please rate & thanks AJ
SOURCE: Activation Code for Fish Tycoon
open your yahoo mail if they ever mailed you the activation code for that game.or emai yahoo requesting activation code.
SOURCE: Acer desktop computer can not open cd-rom drive
try:-
1. select "my computer", right click on cd drive, and click on eject
2. switch off pc,then manually eject cd tray by inserting a strong paper clip in the small pin hole on the front of the cd drive,insert the clip for about 1.5 cm (half inch) in the pin hole and you will feel it press on a lever to open the tray slightly.
SOURCE: I have a cisnet computer and a few weeks ago we
Look in the lower right hand corner - put your mouse coursor over the TIME -- double click it - a screen will pop up and you will see how to adjust the time and set it for automatic daylight savings time.
SOURCE: Non-System Disk or Disk Error Boot from CD
The error means that the CD you have in the drive is not a system disk. Remove it. Are you trying to boot from a CD, if so make sure it is a repair disk or operating system disk. If not, remove the disk and you system will then look to boot from the Hard Drive.
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
