No picture
It might just be that your AV cable is loose. Try unplugging and replugging it in. If that doesn't work, then it sounds like the graphics are going out, which is another semi-common problem with the 360. If it does finally go out, it might show multi-colored lines on the screen, then nothing at all. At that point you can have Microsoft fix it, get someone else to, or look it up and fix it yourself. But be careful, if anyone but Microsoft opens the 360, it will void your warranty.
dude i have the same problem 1 day i tried to get on me xbox360 and the screen just when black then blue:S it wasnt connecting or somin i had everything plugged in properly this is the first time this has happened
no mine is on normal tv. changed cables an tried it on other tv's. no red lights an sound is fine. any ideas??
what type of of connection do you use? Does your xbox have HDMI capabilities?
