Question about Nokia 2100 Cellular Phone
Problem with keypads
The key pad does not respond easily I have to prss so hard before the numbers or the letter appear on the screen.
  • Anonymous Dec 25, 2007
    my nokia 2100 at skrin appreance "contact service" and cannot function at all
My nokia 2100 at screen appreance "contact service" whats means?
Posted on Dec 25, 2007
I will suggest u to change handset keypad.or else go to nokia care centre and have a serviceof ur nokia fone.
Posted on Oct 15, 2007
SOURCE:
How do i get numbers from my key pad as well as letters?
Your NUMBER pad is down in left corner where it has ABC KEY.
It has a ?123 key. Hit it and the alpha keypad will change to numbers.
chad man
Nov 16, 2013 | Acer Iconia B1 7-Inch Tablet Black Dual...
Secret keypad letters in computer
hi
Click on a text box or open a text document.
  • 2 Press the "Num Lock" key to activate your keyboard's numeric keypad.
  • 3 Press and hold the "Alt" key.
  • 4 Enter the numeric code on the number pad. Press "1" to create a "smiley face." Display a musical note by pressing "14". To make a heart symbol, press "3".
  • 5 Release the "Alt" key after entering each numeric code. The symbol will appear.
  • Jan 15, 2011 | Computers & Internet
    Some keys register different characters. For example the O registers the number 6 when it is typed.
    This should be a simple fix, look at your keyboard, you should have a function key and if you look at the number pads above the top row of letters there should be either a numerical symbol or a key pad, your keyb board is simply using several keys as an extended numerical keypad. If you look closely at the letters there are small numbers on them. To fix hold down function key and pressing the keypad button. You can also try pressing the number lock.
    Al
    Aug 04, 2010 | Sony VAIO Notebook
    Keys are not working correctly on key pad
    It may be that you have NumLock on - these function represents a KeyPad on the Letter Keys - usually the U,I,O,P,[,J,K,L,;,M kEYS are replaced with numbers - to switch on/off you should have a key with Number Lock on it possibly abbreviated to NumLck or NumLK etc - activate that Key - may need to use in combination with the FN key as well to toggle the Number Lock on and off - also often a light appears to show its ON
    Apr 13, 2010 | Lenovo IdeaPad S10-1208U Netbook
    My blitz doesnt text
    Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
    Hope this helps, let me know if this works or if I can help you with anything else.
    JimmyC
    Aug 05, 2009 | UTStarcom Blitz Cell Phone
    Keyboard will not work
    Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
    Let me know if this works for you, if not let me know.
    JimmyC
    May 07, 2009 | UTStarcom Blitz Cell Phone
    Voice mail does not respond to commands from auto dialer screen
    i found this on another forum... hopefully it's the answer we are looking for.
    Re: Bug with Phone virtual number pad
    I've found the answer to this problem!
    Part of the problem is that the screen blacks out shortly after a call is connected.
    When that happened I pressed the green phone button to get the keyboard back.
    This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
    After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
    Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
    If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
    If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
    This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
    Dec 10, 2008 | HTC G1
    The letters on my keypad some will only type numbers serial #N326171062571 model MX7625 if i hold down the bottom left key of the pad that displays Fn in blue letters then the letters work instead of...
    1. Open the on screen keyboard by going to "control panel" then "Ease of Access Center" then click on "onscreen keyboard".
    2. click and hold down the "Fn" key on the physical keyboard and then hit F11 on the onscreen Keyboard.
    3. All Fixed. Spread the word.
    Oct 16, 2008 | Gateway Computers & Internet
    Nokia 2100 Cellular Phone Logo
    176 people viewed this question
    Top Nokia Cell Phones Experts
    jonathan mariano
    jonathan mariano
    Ekse
