Question about Metz 45 CL-1 Flash
Metz 45 CL Flash to use with Nikon D90
Hello, I have a Metz 45 CL 4 Flash and I need to use it with a Nikon D90. Can I do this and if so what do I need to get?
This is urgent...any help would be greatly appreciated.
  • Anonymous Apr 24, 2009
    I also have a metz model 45 CL1 and want to know if you can use this with a D90
Metz in Germany advises Models CT45-1 with Serial No's 53400 or less have High Voltage triggers and must not be used on NIKON Digital Cameras Models D70 ,D80, D90 etc.and will damage Flash and even Cameras. according to a email received today. 21/09/2009 Models CT45-4 and 45CL -4 ore ok.
Michael T
Posted on Sep 21, 2009
    Champion:
  • 261 Answers
Yes, no problem.
Buy a Hotshoe to PC from Nikon.
atdlee@netzero.com
Posted on Jun 23, 2009
  • Doberman Jun 23, 2009
    This answer should be rated 100%!
    Yet, shows 85%.
SOURCE:
Will the 45 CL-4 work with a Nikon D600
Yes, if you buy the Nikon AS-15.
atdlee@netzero.com
Mar 23, 2014 | Metz mecablitz 45 CL-4 TTL Flash
Metz 45 CL 4 Compatibility
The trigger voltage of the 45CL4 is right on the borderline, according to this list. Personally I wouldn't use this flash on a digital camera without something like a Wein Safe-Sync to isolate the two devices.
Aug 05, 2012 | Cameras
Is the nikon d60 compatiable with a metz 45 ct4
Will a Metz 45 CL 4 FLASH a SCA 346/2 AFR module work onTTL mode for a Nikon D 70 & D 40X DSLR cameras
Dec 02, 2010 | Nikon Speedlight SB-80DX TTL Flash
Which adapter do Ineed to connect my nikon d90 with metz 45 cl-4 (non digital )
What do you mean by adaptor?! You will need to by a hotshoe adaptor with a hole that talkes the old style cable plug from your Metz lead and away you go! Try jessops. (As long as you have the lead from your Metz!?
http://www.warehouseexpress.com/buy-Kaiser-Hot-Shoe-Adaptor-1300/p1006113?cm_mmc=GoogleBase-_-Studio-Accessories-_-Triggers-and-Sync-_-Kaiser-Hot-Shoe-Adaptor-1300_1006113
Feb 08, 2010 | Metz mecablitz 45 CL-4 TTL Flash
I HAVE NIKON D1X CAMERA AND METZ 45CL4 FALSHGUN. WHICH ADEPTER I NEED TO WORK TTL. THANKS. GOLA.
Im not sure that you can get full TTL with this analogue flash. If you can then SC300 should be OK. (I have the Nikon D80 and TTL is not possible with metzcl4 but who needs it)!
Sep 21, 2009 | Metz mecablitz 45 CL-4 TTL Flash
How can I match Metz 45 CL-1 with Nikon D-80
Try to keep the Flash setting on ISO-setting of 100 constant and adjust your aperture setting on the flash..Do not try to sync with the camera settings..it will normally work...for example.if your camera setting is as this: ISO-400, shutter speed is 125 and aperture is F8, then keep the flash setting as i mentioned above.this setting in an evening environment in a hotel or party event. this may help...
Aug 25, 2009 | Metz 45 CL-1 Flash
Metz flash 45 CT3 compatible with nikon D70
Call Nikon direct in Melville, NY or go to NIKONUSA.COM
Apr 20, 2009 | Cameras
Metz mecablitz 45 ct 1 and Nikon D-90
The trigger voltage of the 45CL-1 is about 12V, so it should be safe to connect directly to the hot shoe with an adaptor, or to the pc soclet, if the D90 has one. If the D90 is anything like my Canon 40D, which can stand about 30V on the hot shoe, then all the 45CL series will be ok, as they have trigger voltages between 9V and 12V. The 45CT-5 has a trigger voltage of 15V and works well on the 40D. I use 3 different Metz 45 models with my 40D and all work well on automatic, where the flash sensor itself controls the light output.
Jan 26, 2009 | Metz 45 CL-1 Flash
Metz 45 CL-1 Flash Logo
1,888 people viewed this question
Top Metz Cameras Experts
Doberman
TimHu
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Metz Camera Expert? Answer questions, earn points and help others
