you need to reboot using your windows cd, when prompted you can press r to repair disk, when you get command prompt, type chkdsk, system will attempt to repair files that are corrupt. If that doesn't work you need to boot from cd and reinstall software..
If you need more info, let me know,
Windows? FILE MISSING is a pretty short error message. Usually there'd be more info, especially that which identifies the particular file that it's missing. This may be an item from one of your startup locations that has been deleted, or perhaps a hardware item that's missing some of it's necessary stuff.
Does your system continue to operate despite the error, or do you halt/freeze?
Hi, When I go to install Server OS in my IBM server machine then I found some error regarding the...
(More)
Hi, When I go to install Server OS in my IBM server machine then I found some error regarding the HDD not found. Can you solve this?
i have a raid controller (ServerRAID-61, Brodcom UNDI PXE-2.1 V7.5.14) on eServer 226. this morning...
(More)
i have a raid controller (ServerRAID-61, Brodcom UNDI PXE-2.1 V7.5.14) on eServer 226. this morning the system was down, when tried to boot up, i get 1962 operating system not found. and also give message No SCSI Controller 3E21"
When I turn off the machine and turned it on again cause it crashed a lot repeatedly until weindows...
(More)
When I turn off the machine and turned it on again cause it crashed a lot repeatedly until weindows came on the screen. when i downloaded or installed any programs but cause it crashed a lot. how can i fix it?
