Question about Epson Stylus Color 777i InkJet Printer
Printer problem got the error message redid the driver reboted the printer wiped down the printer i just put new ink in it it was fine 2 days ago but stopped printing any ideas?
  • Anonymous Mar 16, 2008
    I keep getting error message 31002 when I try to pring a Finale document.
    Genius:
  • 2,985 Answers
What error message? what did it say?
Posted on Aug 16, 2007
Do refillable cartridges cause HP 3650 printer to not print????????
Get new ink cartridges. If they sit that long without being used the ink will dry out in the print head part of the cartridge and clog the very small holes. The clogs are inside the cartridge so wiping the outside will not clear the blockage. In the future if you have to leave the unit without it being used for over about a week you should remove the ink carts and put them in a sealed zip lock bag to prevent them from drying out.
Mar 28, 2013 | HP DeskJet 3650 InkJet Printer
HP Photosmart 5180 has ink cartridge problem, Says following ink cartridges appear to be missing or damaged.
Solution
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.NOTE:The printer will not operate unless all six ink cartridges are installed Step one: Reset the printer Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.Without turning the power off, remove the power cord from the back of the printer and from the wall socket.Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.Check the printer for the error message. If the error message still displays, go to the next step.Step two: Clean the cartridge contacts Lift the top cover. Figure 1: Lifting the top cover Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch.Figure 2: Unlatching the cartridge 1 Black cartridge 2 - Color cartridges Remove the cartridge indicated in the error message.Figure 3: Removing the cartridge Gather the following cleaning materials:Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.Lightly moisten the swab or cloth and squeeze out the excess moisture.Holding the cartridge by its handle, wipe the copper contacts.Figure 4: Wiping the contacts 1 - Copper contacts Replace the cartridge and then close the latch and the printer top cover.Check the printer for the error message. If the error message still displays, go to the next step.he printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.Step three: Replace the cartridge If the error message still displays, replace the indicated cartridge with a new cartridge.
Oct 04, 2011 | HP Photosmart C5180 All-In-One InkJet...
I was installing the yellow ink and then all the sudden after I installed it the message Error Oxc18a0301 appeared! How do I fix this?
Shut down your printer by pressing Simultaneously Cancel + OK + Black + Color.
NOTE: The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or re manufactured ink cartridges. Step one: Reset the printer CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
  1. Lift the top cover. Figure 1: Lifting the top cover
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridge 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridge
  4. Gather the following cleaning materials:
    • Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  5. Lightly moisten the swab or cloth and squeeze out the excess moisture.
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contacts (1) - Copper contacts
  7. Replace the cartridge and then close the latch and the printer top cover.
  8. Check the printer for the error message. If the error message still displays, go to the next step.
    NOTE: The printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
Nov 24, 2010 | HP Photosmart C6280 Printer
Ink repair hp c6180
  1. Lift the top cover. Figure 1: Lifting the top coverc00813643.gif
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridgec00372272.gif 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridgec00372273.gif
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contactsc00372274.gif 1 - Copper contacts
Step three: Replace the cartridgeIf the error message still displays, replace the indicated cartridge with a new cartridge
Nov 13, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink cartridge error
Hp Cartridge issue
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch.
Figure 2: Unlatching cartridge
1 - Black cartridge
  1. Remove the cartridge indicated in the error message.
Figure 3: Removing cartridge
  1. Gather cleaning materials:
    • Distilled, filtered, or bottled water (do not use tap water or alcohol or platen cleaners)
  2. Lightly moisten the swab and squeeze out excess moisture.
  3. Holding the cartridge by its handle, wipe the copper contacts.
1 - Copper contacts
  1. Replace the cartridge, then close the latch and the printer top cover.
Jul 13, 2010 | HP Officejet 5610 All-In-One InkJet...
I have installed 2 new inks and still get a message asking me -- install new ink cartridges to continue .. I purchased these new inks 2 hours ago.
Install the cartridge by following the steps given in this link.
If the problem persists you will need to reset the printer.
Follow these steps to reset the printer:-
  3. Check the printer for the error message. If the error message continues, go to the next step.
Also, Don't forget to remove nozzle protective tape from the cartridge using the pink pull-tab.
Do not touch the copper contacts or the ink nozzles
Good Luck and have a nice day.
Jun 09, 2010 | HP Photosmart D7460 Printer
Brought c5180 two 1/2 years ago. starting using product 8 months ago, printed maybe 500 pages. replace ink when needed. now printer say i need to replace cyan ink which i did twice. brought it in for...
NOTE: The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges. Step one: Reset the printer CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
  1. Lift the top cover. Figure 1: Lifting the top cover c00372271.gif
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridge c00372272.gif 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridge c00372273.gif
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contacts c00372274.gif 1 - Copper contacts
Or Please let me know what is the exact error message you are getting.
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
E5 Error when I reinstalled new & original cartridges
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
597
Jul 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
ERROR MESSAGE : 0502
Hi gtiedith, sometimes the carridge just gets stuck. Leave the lid open. Power off the printer. Clean the carridge metal rod with a tissue. (Just a little wipe should do it. Than grab the carridge & slide it to the right about 2 inches. Close the lid & power on the printer. It should be just fine. Print a test page if you want to.
Have a good day!
Mike
Apr 02, 2008 | Office Equipment & Supplies
Error Message
I changed the black ink cartridge in my printer with an appropriate hp product. I am not able to insert the cartridge correctly in the system. It constantly reads, remove and receck cartridge on right. I have purchased two ink cartridges at this time. Do you think the printer is broken? Please respond.
Mar 06, 2008 | HP Photosmart 2610 All-In-One InkJet...
Epson Stylus Color 777i InkJet Printer Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
