Question about Broan-NuTone Designer 721 Ceiling Fan
Replcing burned out bulb
How do you remove the glass cover with out breaking the glass
  • 625 Answers
Either there are screws for removing the bezel or the whole trim pulls downward. on two sides are two long wire spring clips. once out you should be able to swing the bezel out of the way or by pressing the spring wings together disengage it from inside the can.
Posted on Aug 22, 2007
Have a c970-440793 range. Need to replace the oven lamp light. I have the part in from Sears but there are no instructions.
Just slide the wire off of the glass lamp housing cover. It should just pop-off to the side. Then carefully remove the glass cover so as not to break it. Next, just remove the light bulb by unscrewing it counter-clockwise.
Screw in the new bulb (any small 40-watt appliance bulb will work,) hold the glass cove in place, then slide the wire back over the glass cover. The wire should be centered over the middle of the glass, towards you.
Sep 28, 2015 | In Microwave Ovens
How do i change the oven bulb in jer8885qas
I hope this may help you if it doesnt have visible screwss etc.
Sometimes the glass lenses are held in place by clips behind them which are not visible.
I am not familiar with your machine but I suspect the lens in thick glass and is slightly 'proud' of the oven side.
You have to have faith that it wont break it, but you have to CAREFULLY lever the lens out of its fitting using something like a blunt screwdriver. Once you get one side started, you will get the idea. The bulb is right behind it.
Sep 15, 2014 | Jenn-Air JER8885QA Electric Kitchen Range
Burned out light on bertazzoni hood
Here is how I fix this problem in case someon is still looking for an answer: 1. Turn power to hood off at electric panel 2. Remove light diffusers - these are the round glasses under hood covering the light bulbs. Turn the light diffuser counter clock wise to remove 3. Remove the burned out light bulbs 4. Install the new light bulbs
Jan 05, 2012 | Bertazzoni K48HERX 48" Kitchen Hood
We have a multifunction freestyle over 698 and want to change the light inside the oven. how do we do this
The glass cover over the bulb should screw off, remove the bulb and replace it with a new one of the correct type. Clean and replace the glass cover. Be careful not to use force which could break the glass and cause an injury. Make sure that the stove main switch is off. (The lamp cover may have a screw type or have a bayonet fitting).
Jan 17, 2011 | Ovens
My lowbeams don't come on for my 2005 Volkswagen Jetta. (Although the highbeams do come on.) I just discovered this tonight. Could this be a burned out fuse or other electrical problem?
Removal & Installation
Bulb Replacement
To Remove:
  1. Release the spring clip and remove the protective cover from the rear of the
  2. Disconnect the electrical connector from the bulb.
  3. Remove the spring clip and remove the bulb from the headlight housing.
To Install:
Do not touch the glass portion of the new
bulb with bare hands.
  1. Insert the bulb in the housing.
  2. Secure the bulb with spring clip.
  3. Connect the electrical connector to the bulb.
  4. Install the protective cover on the headlight assembly.
Oct 29, 2010 | 2005 Volkswagen Jetta
How to replace oven light bulb for beko DC543 electric cooker
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    hope u will b helpfull
    tnx for contactin fixya
    Jul 12, 2009 | Ovens
    Elddis caravan porch light bulb blown cant remove cover
    Take a pair of safety glasses, work-gloves, and a hammer, and swing the hammer to break the cover. Remove the whole unit, and replace it with an energy-efficient LED light & socket.
    Apr 23, 2009 | Computers & Internet
    Unable to remove the glass cover to change the light bulb in oven
    I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
    Jan 12, 2009 | Ovens
    Trying to replace main oven bulb: cover jammed
    Try heating it up with a hair dryer or similar if that does not work then you will probably have to break the glass cover.
    Nov 17, 2008 | Neff U1461 Double circotherm plus Electric...
    LG LRE30451SW range
    The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
    Jul 19, 2008 | LG LRE30451ST Electric Kitchen Range
    Broan-NuTone Designer 721 Ceiling Fan Logo
    434 people viewed this question
    Top Broan-NuTone Dryers Experts
    Mike Squire
    Level 1 Expert
    Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
