Question about Cyberhome CH-DVD 300 DVD Player
Dvd player wont turn on
Dont know what is up with this but the power will not come on
  • 5 more comments
  • dolphindown Dec 15, 2007
    My dvd player does not turn on. When I press the power button on the remote or on the dvd player itself, it does not turn on.
  • karvig Dec 16, 2007
    hi,
    When I switched on the DVD,power is not turn on.why?
  • Kim2 Dec 30, 2007
    want power on by the remote or the on and off switch on the dvd player
  • Anonymous Jul 11, 2008
  • mandrgranttx Aug 02, 2008
    my dvd will not turn on
    we have unpluged it
    we have let it sit 4 several days unpluged
    What can we do now?????
  • Anonymous Aug 05, 2008
    Player sat for weeks with red light on. Suddenly there is no red light or green light and it wont turn on with power switch, or remote. Is there a fuse? How could standby fail?
  • Anonymous Sep 26, 2008
    My SA-HT67 DVD player shows "F61" when you try to turn it on, then shuts off right away. What do I do?
    Email me @ [email protected].
  • 3 Answers
One of the previous posts is correct. There was a problem with Electolytic capacitors about 4-5 years ago, which is suppose to be fix now. Many companies tried to get in the business, but did not have the proper formula for them. This left the caps unstable. The caps could last for a week or for years before failing. This affected a lot of electronics from the high priced models to the cheaper. My computer at work (a Dell) and at home had the same problem. There is not a way to tell if a cap is from a bad lot, although there probably a list somewhere. When I'm fixing one I replace all the caps that are from the same manufacturer and same value as the blown one.
One day at work I saw a CyberHome 300 in the recycle bin (someone probably brought it in to fix it and failed). I pulled it out and of course it would not power up. Knowing about the cap problem, I opened it up and sure enough 2 caps were "pillowed" on the top. When a electrolytic blows it may vent out the top creating a noticeable bulge on the top. Replacing the two caps, the unit works great. If you'd like to know more email me at [email protected]
Posted on Aug 09, 2008
These things have poor power supplys.
I to am looking for a burned resistor next to these's caps.
jeaux
Posted on Jul 29, 2008
I fixed mine, open the unit look for bad caps, they look like soft drink cans. Usually the tops of the bad ones are pushed up. Just heat up the solder connection with a solder iron pulling up on the cap to remove it.
I found a 1000 uf 10v cap was bad. It's best to replace
them with one of a little higher voltage rating, I installed
one rated at 16v (16 volts).
You should be able to find these at radio shack.
Posted on Jul 05, 2008
REPR POWER SUPPLY REPL CAPACTIORS
Posted on Aug 16, 2007
SOURCE:
Need wiring diagram
You may download the installation manual here. The wiring diagrams begin on page 18.
Oct 18, 2012 | Panasonic CQ-VD7700U Car DVD Player
Ouku 7" dvd player wont turn on
i have a ouku 7 inch dvd player when evere i turn on the truck the screem turns blue and it has a mute picture that binks on the left side i dont know wht it is can you help me
Sep 29, 2012 | Crown Ouku 7" Single Din Car Dvd Player...
Sdv594 will not turn on
your problem is in the secondary power supply ic 520 memory ic is bad try and get it repaired.but please be reminded that the ic is a surface mount.i would advise you buy a new dvd player but if you dont want to.. have a tech do your repair who can replace your ic.good luck
Feb 27, 2010 | Toshiba SD-V594 DVD Player / VCR Combo
Just stopped working, no power, wont turn on
if your not a technician dont try to open your player, most of fuse now is the holder near where the ac cord is soldered, if the fuse is busted most of the problem is the power regulator.
Aug 28, 2009 | Emerson EWD2204 DVD Player/VCR
Wont turn off
Acually there is a setting by which you can activate " Auto Power Off" in your DVD player. You can make that setting and it will be automatically off after DVD finishes.
May 13, 2009 | TruTech TT320
Disney Princess dvd player will NOT turn on or eject.
On front of television is the video, left and right audio plug ins. This is where you will plug the adapters from your dvd player. They are color coded for easy installation. Step2Make sure the adapter is also plugged in to back of dvd player. Step3Plug dvd player into power source and turn on. Step4On the front of television there is a tv/av button. Press this button twice or until it says video 2 in upper left hand corner of television. Step5Insert movie into dvd player and enjoy. To get your tv back to cable press tv/av button once.
Apr 20, 2008 | Disney Princess MCP DVD2050P DVD Player
Wont even turn on
All things being equal a possible cause is a faulty power supply or bad connection at the power jack. A volt meter will tell you if the power supply is faulty. If the jack in the player is bad/ poor solder connection you might be able to fix it by re-flowing the solder. If it's new doesn't it have a warranty?
Mar 29, 2008 | Insignia PD10135 Portable DVD Player
Need help on DVD power supply repairing..
You dont ,,just replace c10,and c11,,,youll need a solder iron,if you havent done soldering before find someone that has done it before,,youll see c10,c11 stamped on circuit board.
See how much voltage your getting on outputs 12 on one side 5 on other
report progress
Mar 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Lightning Mcqueen TV/DVD COMBO
my lightning maqueen tv dvd player keeps cutin off what do i do
Feb 14, 2008 | Disney Ramone DVD Player
It not turn on
Not sure what kind of connections you have, but be sure your unit is recieving good clean power. Try using another 12v constant and possibly a good 12v switched power source. Double check your ground wire as well. The unit may also be broken and might need service.
Oct 29, 2007 | Pioneer AVIC-D3 Car DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
256 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
