I've just had a Sony HD TV installed by Sony and because of the way the installation was done, I can't play audio CDs if the TV isn't on. The TV is a Sony Bravia KDL-32V400. The DVD player is a Yamaha DVD-S530 and the AV Receiver is a Yamaha RX-V440. I also have cable TV connected
Your description is not entirely clear, so I have to guess a little here, but I think what is happening is as follows:
1) You are using your DVD player as the source for the CD.
2) Your DVD is connected directly to the TV and the TV then connected to your receiver.
If the above are correct, then the problem is that the TV only has what is called an ACTIVE passthru for Audio signals. This means that the signal is process by the TV and tehn sent to the audio output jacks. With the TV off, the buffer ICs are not functioning, thus no output. Some older sets have what is called PASSIVE passthru.
I don't know your specific DVD model specs, so check to see if you have 2 audio outputs from the DVD (many do) and connect the other audio out directly to the receiver. That will resolve your problem.
Dan
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sony Bravia KDL-32V4000 32 in.
I have a sony bravia KDL-40w4500 and i can connect it to a server, my pc is connected to the lcd...
(More)
I have a sony bravia KDL-40w4500 and i can connect it to a server, my pc is connected to the lcd with a network (lan) so i can show/play pictures and music but no video
My tv has a buzzing sound coming out of the speakers. It never did it before. I recently moved and...
(More)
My tv has a buzzing sound coming out of the speakers. It never did it before. I recently moved and that is when it started having a slight buzzing sound from the speakers.
I have an opaque reddish band on the top of my sony KDF55E2000 tv. I just changed the projection...
(More)
I have an opaque reddish band on the top of my sony KDF55E2000 tv. I just changed the projection bulb hoping this was the problem but its still there. otherwise the picture is perfect. You can only see the band when there is something light showing on the screen.
