Question about Kenmore 9387x Top Load Stacked Washer / Dryer
Washing machine My kenmore stacking washing machine vibrates and makes very loud sign during the spin cycle it sounds as if it is coming loose from the drum It only sounds streesed like this during spin cycle. It is Kenmore 99570150
  • 3 more comments
  • Anonymous Mar 13, 2014
    What causes my Kenmore washing machine to be so loud when spinning?
    At the end of the spin cycle the inside drum started to spin uncontrollably and creates a loud banging (marching band) noise. Looks like the inside drum becomes loose and can only stop when it looses momentum.
  • Anonymous Mar 14, 2014
    My ASKO W6342 washing machine drum will not turn on any setting, it fills and drains fine but the drum does not turn during the cycle, however it is free to turn by hand, the belt from the motor is OK, I have removed the back and there is no sign of loose or burnt wires or other obvious problem. When the drum should start there is no sound (eg click or other noise and the motor does not appear to get a signal to turn.
  • Anonymous Mar 24, 2014
    there is creeking sound coming when it spin like some thing hitting the body
  • Anonymous Mar 26, 2014
    F H code comes up 10 minutes into wash cycle then washer makes a beep sound
  • 164 Answers
Check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Posted on Aug 16, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have a Kenmore washing machine model # 11020854990 which recently had a loud banging and knocking sounds during the final spin cycle. Now I notice the drum seems to have dropped down about an inch plus...
Could be a loose basket nut, or on the bottom tub support there are a few springs that help locate the tub. One of the springs could have come off or broke.
Nov 28, 2017 | Kenmore 24032\24036 Top Load Washer
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
My kenmore series 80 washing machine makes a clicking sound during the spin cycle.
Might be something lodged in the drain pipe on the drum, such as a coin or similar object.
Dec 20, 2011 | Kenmore Washing Machines
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Kenmore he2plus vibrate very badly, it is level how do i fix this
My HE2T was making a horrendous sound during the spin cycle. It was making a loud clacking sound and the machine was moving all over the place.
There are two things to check. The first is that the feet are on the floor and the machine is level. The second is a bit more complex. Remove the three screws that hold the lower panel. Underneath the drum on each of the four corners are suspension rods. One side is attached to the drum and the other side is bolted to the bottom of the washer. My bolts loosened up which allowed the suspension rods to clack back up and down as the drum spun. You'll need to tighten those bolts very tight and then give it another try.
Attached on the inside of that cover is the troubleshooting guide. There is a manual diagnostic mode and you can step it to the spin cycle so that you can test the spin balance without having to run through a full cycle. Make sure you have some clothes in there during the test.
Jan 09, 2010 | Kenmore HE2 Plus Front Load Washer
Very loud vibration during the spin cycle, how do you control this only 2 wks old
check the inside of the machine (have to unsrew the top of the machine)each corner should have a rod wich the drum balances on perhaps one has come loose or a spring is gone. possible lol i hope this is some help to you
Apr 26, 2009 | Frigidaire GLTF2940ES Front Load Washer
Loud sounding like loose parts when draining
possibly a coin or hair clip in the pump if not the propeller on the pump may be loose try locating the pump under the machine and try to romove it
Nov 11, 2008 | Kenmore 43052 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Stacked Washer/dryer
possible the bearings are going. place yor hand in the bottom of the drum and run the drum around and feel the bearings for any wear/ noise/vibration. alteratively the bearings in the motor could have gone and spinning with the belt removed would prove this.
Jan 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 9387x Top Load Stacked Washer / Dryer Logo
456 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
