Question about Kenmore 24872 Top Load Washer
Kenmore agitates, but no spin or drain
After agitation it won't spin or drain; timer stops. I can push timer and advance to next wash option but agitation is the only action. I was able to drain the water by lowering drain hose into a bucket. Same for all wash options. Could this have anything to do with the pump? Any suggestions? Thx
  • 641 Answers
Your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley you should remove the pump from the washer and try to rotate its pulley manually. If it doesn't turn freely(frozen or stiff) it should be replaced. In case of a broken pump's belt or belt looks quite worn, replace it. In any case,check the pump's pulley before you replacing the belt. Good luck !
Posted on Aug 16, 2007
SOURCE:
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    Kenmore 70 Series Washer Won't advance in the
    Bad timer. Try to find a used one if possible, this item is a little expensive.
    Aug 23, 2010 | Kenmore Washing Machines
    My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
    Hello there:
    If your cycle does not complete or The cycle doesn't advance
    When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
    Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
    My machine loads and agitates, but will not drain, rinse or spin
    If this is a top load machine check the lid switch.
    If you manually advance the timer to spin, open then close the lid, and get no spin, it is a bad lid switch.
    If it does spin, report back for the next step.
    Apr 21, 2009 | Kenmore Washing Machines
    Washer agitates, drains OK, but spin doesn't start
    Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
    Feb 09, 2009 | Kenmore 23822 Top Load Washer
    Washer only works by manually advancing the dial.
    yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
    Dec 29, 2008 | Maytag SAV3710AWW Washer
    Kenmore 24872 Top Load Washer Logo
    95 people viewed this question
    fordexpert
    Harvey Mahal
    Kristen Denison
    Kristen Denison
    Level 1 Expert
