i hav an amp that i want to hook up to my rockford fosgate rfx-9200 deck but there is a problem with the connections... amp wires have connections for posotive and for negative. in the back of my rockford deck the only connections is 1.where the speaker/ground etc. wires plug in 2. a similar plug in
there is no spot to plug in a negative and posotive amp wire.
is there some kind of adapter i can buy for it?
Comments:
Aug 16, 2007
- well i bought just a simple amp wiring kit from walmart (=D) should that work with my rockford fosgate rfx-9200 to connect it to my amp? because it didn't work...
Aug 16, 2007
- can u tell me where to find a preamp output 3 set for my rockford fosgate????
If you're talking about the amplifier's power terminals, the positive terminal is designed to be wired directly to the battery (be sure to fuse the amp power wire near the battery terminal). The negative terminal should be bolted to vehicle chassis metal for a ground connection.
The only amplifier connections that go to the back of the head unit are the remote turn-on wire and the RCA cables.
Was this helpful?
Yes
No
Popular Solutions for Rockford Fosgate RFX-9200 CD
I need a pin out diagram for a 1999 Delco indash radio model # 09377120. I pretty much have the...
(More)
I need a pin out diagram for a 1999 Delco indash radio model # 09377120. I pretty much have the speakers figured out but need to know the heavy red,yellow and orange/wt. stripe. I can get the radio working but need to know specificly what the heavy wires are for. This radio is in a motorcycle and was wired incorrectly to begin with.
installed speaker last night everything worked fine shut off and when i cranked up this morning no...
(More)
installed speaker last night everything worked fine shut off and when i cranked up this morning no sound mute flashing but shows 30 on display fosgate rfx-9200
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
