Question about Maytag MSD2756G Side by Side Refrigerator
Bottom of Maytag Freezer Ices Up
I have a Maytag Plus Side by Side refrigerator and the bottom of the freezer keeps icing up to the point that I have to end up chipping out the ice on a monthly basis. It also ends up leaking on the kitchen floor. The fridge works fine and the rest of the freezer is no problem
  • 1 more comment
  • nebxetgib Dec 08, 2007
    We have the same exact thing happening with water freezing on the bottom of the freezer and then a new water discharge leaking across the ice and onto the kitchen floor. Any help is great appreciated. Thanks.
  • zebra4 Oct 23, 2008
    I have the same issue.
  • Anonymous Mar 23, 2014
    I need to remove the drawers on my Maytag model mfi2569veb3 bottom freezer to thaw ice and clear the drain
I just had the Maytag repair man out and he wanted to replace to parts after defrosting the freezer. Over $300. He did not have the parts with him. Soooo... I am now in the process of using a hair dryer, even tough it is 107 here today. Ice was totally covering the coils under the back panel in the freezer. Easy to take out. Just remove the shelves and you will see it. If you don't totally get all the ice out it will build up even faster. He claims this will give us 2 weeks or so while the parts on on order. I now have all the ice I can see removed, I just hope it is out of the tube above the coils. I have all my food, lots of good steaks, I want to put back in the freezer. The original problem seemed to be the refrigerator was not working but the freezer seemed to be. Well, it just faked me out because it was just a fan or ?? I heard in the freezer. Wish me luck...MJ
Posted on Aug 31, 2007
We had the same problem; soon your other side of the fridge will start to not cool as well. A circuit board had to be replaced per the Sears repair guy. Cost was about $270 but our icemaker doesn't work so well still. The ice cubes are hollow and it doesn't churn as well.
Posted on Aug 16, 2007
I have condensate leakes into the bottom of my freezer and ices up the bottom of the freezer
YOUR DEFROST DRAIN IS CLOG UP YOU WILL NEED TO PULL THE BACK COVER OFF IN THE FREEZER SIDE AND CLEAN THE DRAIN YOU WILL SEE IT AT THE BOTTOM BEHIND THE FREEZER COVER
Oct 31, 2012 | Maytag Refrigerators
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Fridge Freezer ices up
easy....drain hole iced up....when it defrosts it will flood base of freezer....24 hour switched of to defrst it will cure it
Jul 15, 2009 | Refrigerators
Maytag refrigerator side stopped working; freezer is fine. WHY?
sounds like a defrost problem maytag has problems with the defrost thermostat use a hair dryer to melt the ice on the coils and see if the defrost thermostat is swelled up on the edge
Jun 30, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Warm Fridge
SOUNDS LIKE U MAY HAVE A BAD DEFROST TIMER, CAUSING THE COIL TO ICE UP, AN SINCE THE COIL ICES UP THERE IS NO AIR PASSING TRU TO KEEP THE FREEZER COLD AN THE FRIDGE COOLER, THE FAN MAY BE WORKING BUT IS NOT MOVING ANY AIRE TRU IT, BECAUSE THE BLOCKEAGE
May 28, 2009 | Maytag MB2262H Stainless Steel Bottom...
Samsung frost free fridge freezer ices bottom of freezer
it means that the freezer heater is bad, it's located after you remove the racks from the freezer and removing the back panel, it's at the bottom or below the condenser.
Dec 11, 2008 | Samsung RS2630WW Side by Side Refrigerator
Freezer ices up on bottom where the drain outlet is
clear it again and then go underneith and make the drain hose to shape like a j-trap and it will fix the problem ,,, if you have to, cut a piece of clothes hanger and slide it up the hose and then shape it / larry
Nov 29, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Zanussi 920/g R
your thermostat is faulty you will have to replace it if you keep doing what you are doing your gas will run out ok go to your local appliace shop and give them the model number and they should get you one cheap
Jan 06, 2008 | Zanussi ZEBF250W Bottom Freezer...
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
Dec 16, 2007 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
286 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
