Question about Uniden DCT-7488-2HS Digital Phone
Line always open on Uniden DCT7488
We bought this model phone and one day, for no reason I can find, the phone won't hang up. It holds the line open and no calls can be made or received. I returned the phone and got another of the same model. We've had the new one for about 3 months and now it is doing the same thing. This is two phones with the same problem in less than a year. Any help out there?
  • ccoyle22 Jun 30, 2008
    I have this same problem. I noticed this after a thunderstorm came through. Actually, the outlet where the phone was plugged into had its GFI breaker trip.
I moved some furniture around after christmas and unplugged the phone to do so. Now it does what yours is doing. It needs to be re-set up as if I just bought it. Is it possible yours was unplugged? Suggest you start from scratch with the set-up manual. Personally, I can't find mine. I have the french and am translating it. I can't believe the nonsense I am going through just because I unplugged the stupid phone. Good luck.
Posted on Jan 20, 2008
SOURCE:
How to put line on hold for uniden deect 6.0
Select the model of your Uniden DECT 6.0 system from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Jan 15, 2014 | Uniden Lands Phones
Line on hold
What model Uniden DECT 6.0 phone?
Dec 01, 2013 | Uniden Cordless Phone
I have misplaced my Manual for my phone (DCT7488/DTC7088) and would like to know how to reset time and date etc thank you ,,Marion Huber
You can download the manual from the manufacturer's web site at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DCT7488om.pdf
Jun 16, 2011 | Uniden DCT7488 Corded / Cordless Phone
I have a Uniden Phone #DCT 7488 model. I do not have a manual for it. So how do I set the remote code for to retrieve messages? Is a manual available?
You can download a manual from the manufacturer's web site.
7488:
http://uniden.com/pdf/DCT7488om.pdf
7488-2:
http://uniden.com/pdf/DCT7488-2om.pdf
Mar 14, 2011 | Uniden DCT-7488-2HS Digital Phone
LOST OWNERS MANUAL - LIKE INSTRUCTIONS ON 3 WAY
http://www.uniden.com/pdf/DCT7488-2om.pdf
May 02, 2010 | Uniden Cordless Phone
Handset 2 line on hold cant get it off hold, until then it will hang up when using.
make sure that on the base of the main set that you are plugged into the port that says LINE1/2 and not just line 1
May 29, 2009 | Uniden 5.8GHz Cordless Phone
How to dial out on a uniden Cordless phone on a pulse line
I still need a model number, but if it's not possible and you reeeally want to use the cordless, if you have a modem in your computer, you can have it dial pulse, pick up the cordless, and hang up the modem......
Mar 13, 2009 | Uniden Cordless Phone
Phone won't hang up
I solved this exactly problem by doing this:
1) unplug base station from phone line
2) unplug base station from power cube
3) open each phone and disconnect battery (do not replace phone in charger; just let it sit)
4) wait 30 minutes (per instructions from Uniden)
5) reconnect batteries in phone sets
6) reconnect power cube to base station
7) reconnect base station to phone line
8) test: make a call. Hang up. Wait one minute. Pick up line and see if you get a dial tone.
(Basically you're "rebooting" the system. You don't know where the fault lies, so you power down every component to make sure you get it. The '30 minutes' is longer than I'm used to, but after being on hold with Uniden tech support for 20 minutes and finally getting through, the instructions from them were very clear: AT LEAST 30 minutes. OK! I did it - and it worked!)
Nov 27, 2008 | Uniden 2.4 GHz Expandable Phone System...
Base phone handset #1 holding charge
The base unit should not need a charge. It should be powered by the plug in adapter. It may have a battery to keep operation for a short time in a power outage. The adapter may be loose, the adapter could be broken or the plug in the phone may be broken.
Jun 19, 2007 | Uniden TRU9480 Cordless Phone
Open Questions:
See all Uniden DCT-7488-2HS Digital Phone Questions
Lands Phones Logo
87 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
