Pump is working but is extremely noisy,someone said possibly a bearing.Is this something that can repaired easily or should it be replaced?
SOURCE: Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
SOURCE: de is blowing back into pool,eveythings seems to be hooked uo ok
make shure the pump is sucking not blowing.
SOURCE: jacuzzi pump not pumping
I would probably say that the pump is clogged up or frozen. The motor humms until the heat sensor clicks it off. Try taking apart the front of pump and see if it turns and you should see the problem. Parts are available at most pool stores. Pumps are usually cheaper online.
SOURCE: Is it possible to replace the bearings on a AO
any good electric motor shop should be able to
SOURCE: I have a Hayward Max-Flo II pool pump and it is
Sounds like the bearings but uou would need to take it to a motor shop to have this done. This will cost less than the spectility tools needed to do the work.
Thank you for posting your question here on Fixya.com.
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel. Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings for the motor and a mechanical seal for the pump. All told, depending on the labor rates, it should be less than $75. You could try to repair this yourself however if you are not familiar with the process it is money well spent having someone who is do the repair for you.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
