Question about Toshiba 20HL85 20 in. LCD Television
No Power Hi, Up until last week my TV was working fine. I tried turning it on the other day and the TV was completely dead. No power hetting to it at all. The outlet has power. What's your best advice on this? Thanx in advance. JDS
  • Leprekahn Nov 30, 2007
    same exact problem with the same television toshiba Model 20HL85.
  • kad7777 May 31, 2008
    The AV Assembly board had to be replaced
I'm having the same problem.
check the power supply chord that connects into the tv. I have to adjust a jiggle the chord until the red light on front panel comes on.
The power supply chord needs to be replaced.
Posted on May 31, 2008
SOURCE:
No sound output from my JBL Cinema SB400, tried Bluetooth and HDMI also optical. It was fine yesterday and I turn it on and just no sound what so ever. Can anyone help?
Does the power light come on? If not, check the power cord and power outlet on the wall. Maybe plug in a table lamp to the wall power outlet to make sure the outlet is working. If the power light is on, check the Mute button on your JBL remote control. Also check the Mute button on your TV if sound and picture go through the TV first.
We had a Harman Kardon soundbar (model SB30) made by the same company as your JBL. It worked great for a few months. Then there were a couple of funny high-pitched sounds that stopped when we turned the soundbar off and back on. Then a day or two later we truned on the soundbar and it was completely dead - no sound at all. Harmon/JBL replaced the soundbar under warranty with a refurbished one which lasted about two weeks and dies the same as the first one. Finally, they replaced the second one with a higher model (the SB35) which is still working, although it occasionally makes a rapid clicking noise for a moment here & there.
Dec 31, 2015 | JBL Audio Players & Recorders
Philips HDTV does not turn on
i this problem is in pwoer cord u change it try to on it your problem will be sloves
if the poqwer code is ok then chak your tv trnsformer
May 15, 2008 | Quasar VV-1301 13 in. Combo
Last week my Toshiba picture tube style TV wouldn't turn on.....but now it's on and I can't turn it off. New TV in my future?
You might have intermittent ON/OFF switch. Can't think of anything else according to the description of the fault.
Aug 24, 2014 | Toshiba 32A33 32" TV
My haier htr20 tv wont power up..tv is completely dead.
Check the main power regulator section circuit.
May 20, 2012 | Haier HTR20 20" TV
Hi, Up until last week my TV was working fine. I tried turning it on the other day and the TV was completely dead. The outlet has power. What's your best advice on this?
Take ur tv aparts,where the a/c cord plug in,that ur power supply board.U know basic electronic and soldering?Check for those bad gases leakage capacitors they bulges up it top,or puff up it top.Replaced these bad capacitors will get power back and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 11, 2010 | Toshiba 20HL85 20 in. LCD Television
Tv shuts off after 6-8 seconds
capacitors in the power supply, they all should be replaced, before it takes out the rest of the ps. there are companies that rebuild them if your tech is not up on repairing them.
Jul 23, 2009 | Emerson EWL20D6 Television
TV will not power on
the remote button has change resistance... its a carbon film resistor on board.. cleaning
Dec 15, 2008 | Panasonic PT-47WX49 47" Rear Projection...
I would check the line coil and horizontal and low voltage regulator transistors.
Jan 21, 2008 | Philips 60PP9202 60" Rear Projection...
look for imperfect contacts on the inside main board.
Jan 21, 2008 | JVC AV-27230 27" TV
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Toshiba 20HL85 20 in. LCD Television Logo
246 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
