Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Wurlitzer 1015 problem
I have a wurlitzer 1015. which I had working in a restaurant. After 10 months of use all the moving mechanism don't work at all. The magazine box has no power, the rotary motors for lights and bubbles neither. The cd chander doesn't move, only the lights are lit. Seems that a fuse somewhere is blown..
    Problem Solver:
  • 8 Answers
Most likely the main fuse inside the wurlitzer itself - situated screwed into the lower right hand side of the amplifier panel.
Posted on Dec 24, 2007
SOURCE:
How do I replace the column GE tubes on a 1015 Wurlitzer?
HI,
Here i have added picture of Wurlitzer 1015 rear side picture. from this picture you can identify which side you have to remove to see the tubes. In th picture you can see the tubes. two out put tubes. one rectifier and two pre amp tubes(black).
Wurlitzer 1015
Jul 24, 2012 | Wurlitzer Jukebox 1015 One More Time...
I am moving house and will be moving my wurlitzer OMT, do I need to secure any mechanisms down in order to move it safely ??
Hello qsteven,
With any jukebox no matter what manufacturer, it needs to be locked down to stop the mechanism from being damaged. This is usually done by some form of tie-down bolts on Rowe Ami two bolts hold down the frame other manufacturers do it slightly different.
It is a good policy to make sure that all the circuit boards and amplifier and power supply are secured to the cabinet.
If I move jukeboxes I also tape across the doors to stop them opening during transit to prvent any damage.
Regards
Alan Hood
ami-man
UK
Sep 27, 2010 | Wurlitzer Jukebox 1015 One More Time...
Hello, I have a problem with WURLITZER 1015 OMT CD 100D. The arm go to pick up the CD, but returns in the same time as it lock the cd in the gripper.Result is the CD is supported on two points instead of 3...
The carousel is locked in position by the latch at the front (about 6 oclock). If the gripper isn't exactly in line with the cd then you need to adjust the latch a bit.
Nov 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
How do i move my wurlitzer 1015 cd one more time
I take it you wish to transport your jukebox.
If this is the case I would remove all the CD's (keep them in the order that they were on the jukebox for installation again)
The jukebox mechanism will have some form of tie down system that locks down the mechanism tight into cabinet.
Check the power supply, amplifier etc to see if they pull off their mounts. If they do usually on these parts are holes to insert wood screws to lock them down (use the correct length of screw so they do not damage the cabinet) On the title racks or tubes tape them down so they do not come loose in the cabinet.
Try if at possible to transport the jukebox upright in or on the vehical, cover the jukebox with blankets before strapping to the vehical.
Regards
Alan Hood
ami-man
UK
Jan 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
Record won't retract
If it isn't making any move to retract the tray it's probably the trip switch. If you look in the back and follow the mechanics under the tone arm you'll see how it closes a switch as the arm goes to the centre of the record. Clean the switch or adjust it.
If it is half returning the tray it is the tray stack all gummed up. Use Servisol Silicon spray or have it rebuilt by someone who knows how.
Dec 06, 2007 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
497 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
Mike Duncan
Mike Duncan
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
