When I make a copy or receive a fax, only the right side of the page prints. The other half is blank. I tried to clean as per the maintenance instructions of the manual but it did not work.When I make a copy or receive a fax, only the right side of the page prints. The other half is blank. I tried to clean as per the maintenance instructions of the manual but it did not work.
Two blue locking levers work fine, they were recently replaced. Still only the right side of page prints when copying or receiving fax. Possible pinched wire or what? I'm not eager to take the wiring apart. Any other possible solutions??
[email protected] Two blue locking levers work fine, they were recently replaced. Still only the right side of page prints when copying or receiving fax. Possible pinched wire or what? I'm not eager to take the wiring apart. Any other possible solutions??
One of the blue locking levers is broke. the side that is light is the side the locking lever is n.g. open the top like you want to change the film. there are 2 locking levers. right and left. They are different. if you look close you will see a split in the plastic when it locks down. It is not holding down on one side. I think I have the locking levers. One small screw removes the top plate and you can change them. Lawrence
First step in this kind of issue is check the data cable is properly socketed.
Second step is perform a copy operation directly from the printer. If this fails your issue is printer or cartridge, so swap out the cartridge and retry. If still no copy - your printer has an electronics fault.
Step three is try a document ( D2) from a different application (App2). If it prints the new document (D2) - your issue is with the original document (D1) or the application (App1) printing from. Try printing a different document (D3) from the original application (App1). If document D3 prints from App1 - the fault is in the document D1, and if document D3 fails to print - the fault is in App1.
This is a simple question that I am often asked, and I decided to put together a little guide on how to add page numbers in various programs/applications as well as from the copier's touch screen. Originally I thought this was something that could be dictated from a Sharp print driver, but it's not. It's accomplished by adjusting the settings of the actual document before you print it out.
Print Page Numbers Onto Copied Documents
1. On the Home screen, touch Copy
2. On the Copy screen, touch Others at the bottom-left
3. On the Others Screen, touch Stamp
4. On the Stamp screen, move to the Page No. tab, then choose the location of the page where you want the page number. You can also choose the pattern or text style that you want the page number to be on the left side of the menu.
5. Touch OK. Your copies will have the page number stamped in the position you chose.
Printing Page Numbers from Microsoft Word or Excel on a Windows PC
1. Open your document
2. Once you're ready to print the document, move to the Insert Tab, and choose Page Number, then choose the position where you'd like the page number printed, and the type/style of the numbering. 3. Your print outs will now have the page number printed on them.
Printing Page Numbers from Adobe Acrobat / Adobe Reader
First of all, Adobe Reader cannot add page numbers to PDF print outs. It's a READ ONLY tool incapable of editing documents. You'll need either Adobe Acrobat Pro, or software similar to what BatesNumberer.com offers.
There is a great video on tv.adobe.com that details how to add page numbers via Adobe Acrobat.
In Conclusion
Make the necessary changes to your document to add page numbering before you print it, or before you copy it. There are a ton of other great tutorials for Sharp copiers/printers at www.youtube.com/equipmybiz
You can download the manual from here: Reference page 24: "Collate With the Collate check box selected, one complete copy of your document will be printed and then repeated for the number of copies you selected. If the Collate check box is not selected, then each page will be printed for all the copies selected before the next page of the document is printed."
What document you are trying to print?
If it is Excel or Word document you have created a second blank page, reopen the document and delete the second empty page.
Your fax can print a list of documents stored in memory, along with the transaction number (TX/RX NO.) of each document. Once you know the transaction number of a document in memory, you can print it or delete it. 1 Press [Menu]. 2 Use [up] or [down] to select , then press [Start/Copy]. 3 Use [up] or [down] to select , then press [Start/Copy]. ? Printing a Document in Memory 1 Press [Menu]. 2 Use [up] or [down] to select , then press [Start/Copy]. 3 Use [up] or [down] to select , then press [Start/Copy]. 4 Use [up] or [down] to select the transaction number (TX/RX NO.) of the document you want to print, then press [Start/Copy]. The LCD toggles between and . If you are unsure of the transaction number (TX/RX NO.), print a list of documents in memory (see page 34). 5 Press [*] to print the first page only, or press [#] to print all pages of the document. The fax prints the document.
give print...select printer ....goto properties of the printer in the same dielog box.....then ....more page layout options .....there you can change the page scaling
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
[email protected]
