Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic pt-47wx53 problem
Was playing a game and during this time tv made high pitched crackling sound then screen flicked black, then it worked again then crackled again then turned off completely then I smelled a slight burning smell.
    President:
  • 3,130 Answers
What does the light on the front of the TV set do. This is a self diagnostic tool. How many times does it blink?
Posted on Aug 16, 2007
SOURCE:
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Crackling when turned on then high pitched howl and sound like vinyl being played loud and having stylus dragged across it is the only way to describe the noise after howl. was being used and did crackle...
You didn't say whether it was one or both channels. The word to describe the noise when using a turntable, back in the days, is called Acoustic Vibration. Your issue is not that. I can be an amplifier oscillating, for the high pitched sound and the crackling could be DC Offset*meaning a damaged amplifier) If you need further assistance, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
Oct 26, 2014 | Audio Players & Recorders
Protron tv crackling sound
The speakers that are inside your tv are damaged and needs to be replaced, after you replace your speakers, the Sound will return at the correct factory settings from which you received your tv..
Feb 10, 2013 | Protron PLTV-37 37 in. LCD Television
Vizio high pitch noise while watching
It sounds like the speaker wire it not grounded good. It sounds like a high pitch whistle or crackle.
May 05, 2012 | Vizio E470VL 47 in. HD-Ready LCD TV
First of all, sorry for the mix up on model the model #. I was viewing a problem regarding LG LCD TVs and found your link. My problem is with an LG 42LGX LCD HDTV. It has worked fine without any issues...
welcome to fixya and thank you choosing my service..
OK,that is the most and common problem of all LCD TV...
Usually dim and totally have no back-light is cause of bad inverter board.One of the inverter board is shorted that cause dim light and crackling sounds..
This are the sample images of inverter board.
to make sure that the problem is on the inverter board kindly try to disconnect/unplug it from your TV and power ON then observe if the crackling sounds remain or not..If the crackling sounds gone replaced the inverter board..Also I need to how many inverter board you have? if 2 or more disconnect it one by one to determine if where is the specific faulty inverter board..
Example:
I disconnect #1 inverter still have crackling sounds..next disconnect #2 inverter and reconnect the #1 inverter until you found the faulty one..Note when you doing this make it sure you power off the TV before you unplug or disconnect inverter board because its high voltage..
I need the picture your TV screen..just send it to [email protected]
Regards.
Chester
Jan 20, 2012 | LG 42LC2D 42 in. LCD HDTV
Crackling Speakers
It sounds to me like an impedance mis-matching problem!!!
But it does seem you have done everything correctly so I cant offer any other suggestions - sorry!!!!
Aug 01, 2008 | Pioneer VSX-D407 Receiver
Audio crackles at normal volume with game discs
they said there would be a problem for LG tv's try going to your settings audio settings and change stuff around
Jun 24, 2008 | Sony Playstation 3 (PS3) Console
Cracking noise and flickering screen
Sounds like you have a bad flyback Transformer...Crackling is high voltage leaking. I would quit turning it on and replace the main board in the set if you are good at soldering you can replace the flyback transformer but cost wise it is easier to replace main board. 20" might not even be worth the repair.
Nov 02, 2007 | Insignia IS 20" TV040919 TV
High pitch crackle buzing sound when set turned on
Did you find a solution because I have the same problem on my JVC?
Nov 14, 2006 | JVC AV-27530 27" TV
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
