Question about Samsung MM-DS80 System
Display screen says protected
The display screen says protected and there is a weird low tone sound from the sub woofer and nothing works! The unit stays on for a few seconds then turns off automatically. The manual said to reset it by turning it on then off and hold the SRS WOW button for more than 5 seconds. Ive tried that and it did not work still the same, the screen read protected. I even tried to pull the plug out and leave it out for a few hours but no change the screen read protected!!! Any help would be greatly appreciated! K-SPOT
  • Anonymous Jan 27, 2009
    I was playing a DVD today - (which had been recorded from the TV) - all previous playings were fine - I switched over to tv and watched a little tv today afterwards without a problems.
    went out and came home after a few hours have switched tv back on and now the home cinema system (DVD player) screan comes on - says Hello then Protected and turns off ! - AGGGGGHHHHHHHHH......
    After re-reading the instructions several times there is no mention of this does anyone know what to do to solve it...
    The system is Samsung running with a Samsung TV and is only 2 months old !
  • Anonymous Mar 30, 2014
    when i went to change clock to bst machine locked up and went on to preoaring mode have tried pulling mains plug still wont work remote wont work all buttons wont work the only thing that is working is the cooling fan and the digital display saying"prepairing" please help
By your description it looks like an internal protection has tripped. The reset will not work if the unit is fried. Did this happen when you were pushing the unit really hard or distorting it? You may have to have it repaired, or replace it. Repairs can sometimes take a couple of months so be wary of this.
Posted on Aug 17, 2007
SOURCE:
Pioneer cx4000 home stereo no rear speakers/subwoofers very low sound. only surround sound works normally
Either the sub woofer speaker or the sub woofer amplifier section circuit has the fault. Contact any service technician to make diagnosis the faulty section. If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand devices are given. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 04, 2016 | Pioneer Audio Players & Recorders
I have a quantum audio equalizer and the sub volume doesnt work wats the problem?
are you getting any sound at all out of your sub woofer? what about if you bypass the EQ? If you're getting sound but just not the control over it then the Potentiometer (the volume knob) is bad or has become loose from the connection to the board. More than likely you would not have any sound at all if it's loose. If you have no sound and you are not getting sound after bypassing the EQ then check your head unit settings to make sure that it is set to have full frequency output of the RCA's. It may be set for high pass which will filter out the low tones, leaving nothing for the EQ to work with.
Apr 02, 2013 | Car Audio & Video
I have a MTS surround sound system and when i put the volume up the woofer turns off. whats wrong with it? and how can i fix that
Seems you are over driving the unit and causing it to overheat and the protective circuits are kicking in. U need a more powerful system to play at the volumes you want.
Aug 26, 2017 | Audio Players & Recorders
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
level.
Jun 25, 2017 | Yamaha RX-V861 Receiver
No sound
if the display is working your pre-amp is ok
check the sub-woofer
amplifier is in the sub-woofer, check fuse inside first
after that mail again, thanks
Feb 15, 2010 | Bose 3 2 1 GSX System
Low sound and buzz from speakers / Hum noise from sub-woofer
Select Start > (right click) My Computer > Manage
In the Management window select > Device Manager
Next to Sound, Video and Game Controllers click the + sign
A yellow triangle will signify a problem so if one is present, right-click that device and select Properties
You can then choose to update the driver
For more details check Dell Xps 420 Manual.
Dell Xps 420 Manual
Apr 14, 2017 | Dell A525 Computer Speakers
How do you adjust the bass levels on a Yamaha HTR6130 receiver? I can get the display to show Bass 0db, but what button changes the settings?
When you touch tone button on your front panel repeatedly, you will get two option for setting bass and trebble, when you select Bass immediatly press your updown Sound field Program Button.
Please note:for better sound if your using Small front speaker keep bass to 0db and select the low frequency through sub woofer and program manually LFE from only Sub woofer and addjust CUT off frequency of Subwoofer to 160 and incase if your bass is not clear put it into rev mode.
Oct 05, 2009 | Yamaha HTR-6130 Receiver
I am not getting power to my sub-woofer that i added on sub works fine just no out put to it checked resistance getting nothing
Nothing = zero or nothing = infinite?
If it is essentially zero, you are probably OK since the DC ohms of nearly any speaker measures very low resistance; they are rated in impedance which is a complex combination of  resistance (R), inductance (L), and a little capacitance (C) and becomes the 'Z' of the rating of (typically) 4-8 ohms.
If it is measuring open (a flashing display on any resistance range of a digital meter), then you probably have a problem.
You can safely take a single flashlight battery (or any 1.5 volt cell) and apply this by tapping across the input of your sub-woofer. If it makes a fairly loud 'click' then the speaker is functional.     If it passes the test, you have connection or output problems from your amplifier.
Feb 28, 2009 | Technics SC-DV290 System
Sub Woofer feedback
That is weird. Did they ever work? try calling their support:
General Product Phone Support (United States) +1 646-454-3200
Monday - Friday: 6am - 6pm PST
Saturday - Sunday: 7am - 5pm PST
Mar 31, 2008 | Logitech X-530 Computer Speakers
Samsung MM-DS80 System Logo
146 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
