Question about T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 has problems
My sidekick 3 wont charge by itself. i either have to put something up against it or play wth the wire. in all, te port is weak. then my phone retarts alot. id be talking and it restarts and wont come all the way on. what should i do?
Get a new battery
Posted on May 04, 2008
  • robd1234567 May 04, 2008
    same EXACT thing happend to me and i just got a new battery so yea do that
He means it will stop halfway and turn off and turn back on and stop half way
Posted on Nov 18, 2007
    Problem Solver:
  • 8 Answers
It sounds like the prong in the middle of the AC input is loose and therefore not making a good connection with the charger. What do you mean when you say "it won't come all the way back on?"
Posted on Aug 17, 2007
Tmobile sidekick3 wont charge
It's called the sidekick 3 charging port and they are known to go bad a lot.
You can check out cellulardr for the repair. It runs about 75 dollars or you can get a external battery charger cradel and charge the battery outside the phone.
Feb 17, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 wont go past BATTERY LOW! PLEASE ALLOW DEVICE TO ..
turn off your phone. then remove the battery for 5 minutes. also make sure your charger is not plugged in. then put the battery pack into the phone. it should clear up. also you might have over charged the battery. another solution is to buy a new battery pack and if that does not work your phone is acting up on battery basis
Jan 20, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
If the orange light is coming on, but not charging the sidekick then the charger port is probably bad.
It's about 80 dollars to fix at cellulardr or you can do a work around and charge the battery seperate from the phone.
check out the charging cradle here:
Sidekick 3 spare battery charging cradle
Dec 13, 2008 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile won't fix my Sidekick 3
best bet is the mini usb jack is faulty where the charger plugs in to. could be the charging base needs to be re soldered. take it to an electronics tech, or your local service centre.
good luck
Nov 01, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick wont turn on
If you can, try a friends battery, either from a sidekick ID or sidekick 3. The Sidekick ID seems to be having the same issue as the sidekick 3 whefre the charging port goes bad. The best worka round for that is to get a charginfg cradel that has a spare battery slot.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 23, 2008 | T-Mobile Sidekick ID Cellular Phone
My sidekick wont work
It seems your charger port is broken, it hapfens often on cellphones, wear and tear. Check to see if its under warranty, and it can be replaced. Check my profile if you need more help.
Jan 24, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
You Blew A Circut In the Charger Port Depending On the wattage of that wrong charger. Now HeresWhat you do. you Need to find out if you blew all the circuts in the phone or just the one for the charger port, Find Some One With A Sidekick Test the battery in your phone make sure its fully charged, If your Phone Comes on the rest of the circuts are fine, if it doesnt you need a new mother board. If It Does U Need To Have the Phone Repaired. Call Me 347.845.7151
PLz Be Sure To Mark The Problem Solved
Nov 26, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Side kick 3
The sidekick 3 has a charging problem on some models.
It's not the battery or the charger but the battery charging port.
Call t-mobile if it is under warranty.
If not you can use a work around that charges the battery outside the phone.
Check out this site for more info.
Sidekick 3 charging problem
Nov 22, 2007 | T-Mobile Sidekick® 3 Cellular Phone
hey, my sidekick3 screen won't light up
and my buttons wont light up either.
and suggestions?! please help
Aug 20, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
178 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
