Question about Durabrand DWT1304 13" TV
Connecting VCR/DVD The DWT 1304 won't recognize either VCR's or DVD's that I connect to it. The VCR in particular ought to be duck soup-- audio to audio, video to video; that's all. But though the tape plays (and it plays fine on other TV's--the tape itself is OK) the 1304 doesn't know it's there. I get the standard black screen (just a little bit of fuzz) on which I can call up the menu, set picture quality, game mode, and whatnot--but no matter what setting(s) I choose there, I get no audio or video from the VCR. Same result when I try connecting a DVD player. I guess I've just graduated to the status of clueless senior citizen. Thanks to anybody to cal suggest what stupid thing I might be doing wrong.
I had the same problem. YOu have to press GAME on the remote that comes with the TV. There is not TV/VIDEO button- that's what the GAME button does. I stumbled on the answer by accident. Hope that helps! JRK9574
Posted on Aug 20, 2007
  • monarchtc8
    monarchtc8 Dec 30, 2012
    this worked for me! Thank you!
    Novelist:
    Champion:
  • 236 Answers
Does your TV have more than one A-V input ? If so perhaps you're plugged into the wrong input. Make sure you're coming out an output on your VCR/DVD player and going into an input A-V plug on your TV. Stargazer I've messed up like this a few times!
Posted on Aug 16, 2007
No video after connecting dvd/VCR cables
The basic DVD/VCR connection consists of three cables: red for right audio, some other color (white?) for left audio, and (usually) yellow for video. Is this how you connected yours?
Nov 26, 2012 | Emerson SLC195EM8 LCD TV
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
I'm trying to get my dvd recorder and vcr hooked up to my new flat screen tv. How do I connect them and what channel do I put my tv on (flatscreens don't have channel 3 or 4) to recognize the dvd recorder...
DVD players do not connect using regular cable connections Your flat screen TV should have separate Audio and Video connections. These are the connections that you should use to connect your VCR and DVD player. If you have a combo unit, that is a single unit that has both DVD and VHS in one box, you might be able to get your VCR to work on the cable connection. However your DVD will not be able to work as the cable connection doesn't allow enough information to pass through. If you go to your local Audio Video store and tell them what you want to connect they should have the cables you need for less than $10.00. Good luck.
Sep 15, 2009 | Televison & Video
Will an RCA Digital Convertor work on Durabrands model #1304.?.
Hello chlpepr2,
Yes it should work, connect the RCA video out (yellow connector DTV Converter) to the RCA video in (yellow connector TV set). Then connect the RCA Audio out (Red-Right White-Left DTV converter) to the RCA audio in (Red-Right White-Left TV set).
Then setup your converter box according to the manufacture's instructions.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 20, 2009 | Televison & Video
Dvd player
Try accessing the 'Game" mode from the Menu button on the TV. User Manual for Model DWT1304 is available online at http://funai-corp.com/support/manuals.aspx
Feb 15, 2008 | Durabrand DWT1304 13" TV
Unable to get sound when connecting DVD player to TV
connect one end of white cable to dvd/vcr audio output and the other end of white cable to tv audio input L .
connect one end of yellow cable to video output on dvd/vcr and the other end of yellow cable to video input jack on tv
If you connect like this after checking you connections this should fix problem.
Jan 02, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Connecting VCR/DVD combo
Confusing! TV with NO yellow,red white input ? Buy an RF
adapter Radio Shack about 30.00.....TV has input ? = yellow
video,audio R,L from Insignia source dvd/vcr out ( audio R,L,
video {yellow} ) You don't need to switch cables.As to record
feature,consult owners manual..................................T
Nov 21, 2007 | Televison & Video
Sanyo TV
If I understand your posting/description right, you have:
1, a Sanyo TV with only 1 video input;
2. you have a DVD player with only video output; and
3. you have a VCR (which I will assume to be with both video input and output).
Your query, if I may clarify, is how to hook them up so that you need not connect/disconnect any video cable when you want to switch video source from either DVD or VCR.
If that is what you want, then connect:
a. audio/video OUT of your DVD to audio/video IN of the VCR;
b. audio/video OUT of your VCR to audio/video IN of the TV.
The above described connection would allow you to:
i. watch DVD movies on your TV (your VCR must be powered ON and set to Video INput, your TV must be powered ON & set to Video INput);
ii. watch tape movies from your VCR without disconnecting/connecting cables.
Additionally, this arrangement would allow you to record DVD movies in your VCR. Further, connecting your cable/aerial to the RF INput of your VCR would allow you to do the same with a TV/Cable program.
Incidentally, if one of your units (TV, VCR, DVD) would only have a single audio input, it is still possible since some models uses the white audio RCA connector as either left or mono, the red is right. You can also use a 2 female RCA to 1 RCA male adapter as shown below to joint the red/white audio.
Hope this be of some idea/help. Pls post back how things turned out or should you require additional information.
Good luck and kind regards.
Nov 19, 2007 | Sanyo DS32224 TV
Multiple video inputs
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Mar 22, 2007 | Sony KV-32S26 32" TV
Durabrand DWT1304 13" TV Logo
289 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
