Question about HP ScanJet 6200C Flatbed Scanner
Makes grinding noises, refuses to scan; WinXP
We were scanning some papers when suddenly a notice appeared "could not initialize device". Went through the HP diagnostics resulting in downloading 9 new updates. Re-booted the computer as directed and tried the scanner again. It now refuses to move the light bar and the drive stutters and makes terrible noises. At one point I had to lay it on its side could that have caused problems? Thanks for your help.
  • jdnickell Aug 16, 2007
    Where is the closest repair station to Coeur d'Alene, ID?
  • 56 Answers
Take a look on the underside of the scanner. there may be a switch that goes from lock to unlock. try to move it to lock and back into unlock. this lock is usually used to lock the bar from moving during shipping. if this got moved back to lock or bumped while you had it turned over, the scanner will not allow the bar to move.. try this first.
Posted on Aug 16, 2007
  • 3 Answers
In my slightly different case, a HP Scanjet 7400c) made grinding noises right after the bar reversed direction.
First greased some parts but that didn't help much.
Then noticed there is a spring that tensions the belt. Replaced that spring and it instantly cured the problem.
Makes grinding noises, refuses to scan; WinXP - makes-grinding-noises-refuses-scan-tx4ynd2s3fuel3vgdkbfoa1d-3-0.jpg
Posted on Jun 25, 2015
SOURCE:
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
Upon completion of OCR scanning, why does the printer make a grinding noise?
When you scan the document, the laser module moves on from the start point of the location to the end point of the location boundary for scanning the document and then it comes back to the initial position to the start point, so while moving the laser module it makes some sound. Still it is advised to take the printer to the nearest Canon Service Center to check if it requires any servicing. Please find the link below:
https://www.usa.canon.com/internet/portal/us/home/support/service-repair
GuruAid.com
Mar 27, 2016 | Canon PIXMA MG8120 Inkjet Multifunction...
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
HP C310A grinding noise
Grinding noise is unusual. Check for the following ...
> Place the printer on an even surface.
> You may remove the ink cartridges and install them back.
If issue still persists, please call HP Tech Support as the printer requires a service.
If you are from USA and the printer is Out of warranty, then you may be provided an option to Trade in.
If issue still persists, please call HP Tech Support for further assistance.
If you are in US , the toll free # is 1-800-474-6836 .
If you are not in US , then log on to www.hp.com , at bottom-left corner there is a world map icon, click on it and then select the region you belong to, which would then provide support options for you for that region.
Apr 01, 2013 | HEWLETT-PACKARD C310a All-In-One InkJet...
Grinding Noise in my scanner
Try cleaning the guide bar that the scanning head rides on, apply a thin film of lithium grease on the guide bar
Apr 15, 2009 | Epson Perfection V100 Flatbed Scanner
2410 Malunction
This problem always hits after a power interruption. On another site I read the solution is to open the back and roll or move the paper wheels back and forth a few times. This worked for me.
Apr 21, 2008 | HP Photosmart 2410 All-In-One InkJet...
HP ScanJet 6200C Flatbed Scanner Logo
757 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
