Question about SanDisk Sansa e260 MP3 Player
Wont play music
My player will only play one song and if i put it on random and try to move to another one the screen freezes and im returned to the main menu but the videos and radio still work.
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
SOURCE:
Why does sony E436F MP3 player change the order of the songs
Your music has likely been put on shuffle. Look on the screen while songs are playing. You will see two crossed arrows or the word shuffle or random. Check playback options and see if random or shuffle option has been turned on. Sometimes the program you use to put songs on the MP3 player will activate this option if the program's playlist is on shuffle.
Dec 16, 2009 | Sony NWZ-E436F MP3 Player
Iriver E10.....wont play songs
well it seems you deleted your songs but not the titles. weird huh but that happened to me too. so hook it up to your computer, go to " my computer", and then right the icon that is your device, and then click format and that should take care of that.
May 28, 2009 | iRiver E10 Digital Media Player
GPX ML648B wont shuffle -- not an option?
There is a RANDOM option. But I've found that it is restricted by folder. It's best used when you've moved all your music into one folder.
To turn this option on,
1. play a song
2. press the button on the side
3. select PLAY MODE
4. Choose RANDOM
Mar 31, 2009 | GPX ML648B MP3 Player
When I put music on my spi mp3 video player, the songs say "unknown format" and wont play???
the music format won't be acceptable by the player
you need to change the music format first, to do so, you can use
audio converter. few mouse clicks is enough, good luck
Mar 27, 2009 | Zvue Spirit MP3 Player
Sylvania SMP2002 Shuffle?
how do i play the songs on my songs on my sylvania smp2002 mp3 player because it wont play
Mar 09, 2009 | Audio Players & Recorders
My zen wont play an y music
try sliding down the power button while holding down play and resetting the zen while the player is off, this should bring you to the zen format screen thing, select "clean up" if this doesn't work try selecting the other options from the zen format screen thing.
Jan 18, 2009 | Creative Labs Zen Digital Media Player
My mp3 on my pantch matrix wont play the music from the external
I had the same problem. I put music on my SD card, and whenever I tried to play it, my phone would reset. I looked through the files, and found that the songs i had bought on iTunes were all in MP4 format. I downloaded the 4media mp4 to mp3 converter, and converted the files. When I put the card back into my phone, the music player worked perfectly!
Note: MP4 files DO NOT have question marks beside them in the phone. The only way you can tell is to highlight the files on a computer. Hope this was a help!!
Jan 16, 2009 | Pantech Matrix Cell Phone
My Mp3 wont play certain songs
Sounds like you have two problems here. First my guess is your files bought from walmart are corrupted some how. just delete the ones that are giving you fits and call it a day. Second you mentioned it wont even sync music,,,, Are you saying none of your music or just the walmart ones ?
Nov 17, 2007 | SanDisk Sansa e260 MP3 Player
Certain songs wong work
get a refund. It needs to be relicened on the net
Nov 09, 2007 | SanDisk Sansa e260 MP3 Player
Songs wont change
It is stuck on "Repeat One" - refer to p.23 of your user's manual -
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
While you are playing music you can see the following active play mode screen.
-Tha Mp3 Doctor
Oct 30, 2007 | Philips HDD1630 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
