Seiko Kinetic watch Logo
Anonymous Posted on May 26, 2013
Seiko 5m43-0b19 is stopped & jump 3 to 5 seconds fast
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Jan 03, 2010
SOURCE: seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Seiko instruction adjustment instructions day date
The crown ( the winder as used to be) will pull out one ,two, or three stops. Each stop does somthing different.e.g. 1 - hands, 2 - day, 3 - date. Sometimes, the second stop will do two functions - turn one way for day and the other for date.
1helpful
I have purchased a new Seiko kinetic SUN007 mens watch. After hours of swinging back & forth to charge the watch, the 'second' hand still moves in two-second increments. (After charging via movement,...
I have a Seiko kinetic watch and it has behaved perfectly for over two years and therefore I think that yours is faulty.
I suggest you send it to Seiko to have it repaired or replaced under warranty.
6helpful
3answers
My seiko 5 automatic runs to quick
Balance spring in your watch is sticking together and causing the watch to run fast. It can happen when watch gets magnetized or there is some oily residue left on balance spring. To fix this you will have to show your watch to the watchmaker, because this is very specialized job to do and the balance spring is so delicate part, it can be damaged by simple touch.
3helpful
Seiko SGF204 second hand hesitates or jumps a second and looses probably 10 minutes an hour. Any suggestions would be appreciated. Thanks
When the watch jumps a second or seems to stop then tick twice, it indicates that the battery is low. You will need to take your watch to have the battery replaced.
2helpful
2answers
My seiko is keeping good time but the second hand jumps two seconds then hesitates for what seems to be a second then skips two seconds again
There are three solutions for this problem, contingent upon the model:
With both instances, this is a power saving / low charge / low battery feature of the timepiece.
1) Is your Seiko watch a Kinetic / Solar model? If so, your watch contains a capacitor. The capacitor may be bad, OR if you have not been wearing it on as regular a basis, wind the watch (Kinetic) vigorously for 5 minutes, and if the second hand returns to normal function, the capacitor is most likely fine. If is is a Solar model, expose it to sunlight for 4-6 hours or incandescent light for 24 hours and see if this resolves the problem.
2) Else: if this is a standard battery operated watch, take your watch to an authorized Seiko repair center, or Certified Master Horologist. Make sure that the Seiko Repair Center is using Seiko batteries, else make sure they are installing Energizer only - these two batteries will not leak in your movement. Avoid other batteries at all cost, many of them will leak and ruin your movement.
3). If these solutions do not work, and you have not had your watch serviced in the last 3 to 5 years, you need to service the movement. See the aforementioned parties to begin the process.
4) If your watch is water resistant, and/or you plan on wearing it in the water, make sure to have your watch water tested by the appropriate aforementioned professional to ensure it will withstand proper dynamic and static pressure at the appropriate depths.
Feb 04, 2011 • Watches
Please help My seiko 5 superior 23 jewels is moving too fast,every 1 hour it'll be 2 or 3 minutes sooner than the other watch, how to fix it? thank's
mcdevito75 here, You could have a bad hairspring or faulty mainspring in your seiko, look for a small watch repair shop im yyour area for repairs.
3answers
My seiko kenetic watch stopped, and will not say wound
I thing required cleaning for the movement and new capacitor.
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
11helpful
Reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
Chicago, IL 60601
Ph: 312 641 7000
Aug 28, 2009 • Watches
15 to 20 minutes fast per day
if your caliber is automatic 7s26b something is wrong with the hair spring try a seiko service center anyway isnt something that you can fix by yourself!beware!far away from jewelers and local battery changers and other monkey magicians!automatic watch calibers are delicate and they ruine them!
3answers
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Top Seiko Watches Experts
Paul Bade
Ngoro
Are you a Seiko Watch Expert? Answer questions, earn points and help others
