Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Display mode problems usaing component cables
My Philips DVD recorder is connected to the LCD with component cables. Problem is when I play DVD's the display mode of the TV is disabled and defaults to Widescreen. This stretches and distorts the image vertically. This does not happen with composite or s-video connections and the display is correct proportionally or can be adjusted using the TVs screen mode setting. Any ideas
  • glenwood52 Aug 16, 2007
    Sorry I meant to say it flattens the image vertically
  • 138 Answers
Is this a high def dvd player and see if you can go into the dvd menu or on the dvd remote to find a formate button. If not give me the dvd model number please..
Posted on Aug 20, 2008
SOURCE:
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
We have a Philips DVD Recorder a Freeserve Digital box and a TV. Since adding the DVD Recorder we cannot tune in Freeserve at all and DVD's play only in black and white. Help Please. ...
Hi Jack,
And if you remove the DVD Recorder, everything is back to normal?
Initially, I would suspect that your DVD is set to PAL system and not to NTSC (or could be the other way around). Could you pls post back with the exact model number of the Philips DVD Recorder?
Additionally, could you pls detail how the Freeserve Digital box is connected to the Philips DVD Recorder and then to the TV? Pls indicate if you are using Video IN/OUT, S-Video, HDMI, SCART, RF IN/OUT.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Televison & Video
A/V Signal Outout through Onkyo TX-SR705
Are you trying to record cable programming with your DVD recorder? If so, you might want to try using component cable as HDMI does have a copy protection circuit that might be preventing your recorder from receiving the image. Just try to connect the cable box component (RED/GREEN/BLUE) cable to your DVD recorder. If that doesn't work, then try to change everything over to component cables. HDMI is a great cable to use but it the only required to display 1080p images and the only current source that uses 1080p is a bluray player. Everything else, such as your cable box and DVD recorder is 1080i and component cables are perfect for it.
Mar 14, 2009 | Toshiba RD-XS32 DVD Recorder
My philips dvd player does not show logo on the screen if i play any dvd ,only sound was hearing what can i do
Check the video connection. Make sure if you are using component cables that it is connected to video out on the dvd player & video in on the av slot of TV. Hope this helps.
Dec 25, 2008 | Philips DVDR3390/37 DVD Recorder
Cannot view tv program while recording on VCR
Hi and welcome to FixYa,
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
How to hook up a dvd recorder with HTS6500/37?
Suddenly had this problem. My Phillips is hooked up to TV and to Cable Box. When I inserted a DVD it would return a "no disc" but it would read and play CDs. After a call to Phillips...who said that they had no idea what was going on and I should take it in for service...it was 4 months out of warranty. Repair company said it was not worth the repair costs ($200) so I should try cleaning the lens with a lens cleaning disc. I bought a Maxell. It has a set of little brushes on the bottom of the disc. I inserted it and played track 2 for 20 seconds as instructed and voila! It began reading the DVDs again. I was only out the $10 for the disc cleaner. If you have this problem, try the disc cleaner first as it might be the fix.
Oct 03, 2008 | Philips HTS-6500/37 System
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Samsung dvd sh-855 i have the same problem wiht freezes when recording on timer mode.Recording in timermode with TV on is OK. But only connected whit HDMI cable, Component is OK in all modes!!!
My recorder is a XXE model = scandinavian.
Do anyone have a solution Please
Apr 20, 2008 | Samsung DVD-HR720 DVD Recorder
Will not play
does the player turn on? it might be a display setting on your tv- meaning it has to be on a set channel or mode to work
Dec 27, 2007 | Philips Magnavox MWR10D6 DVD Recorder
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
