Question about Brother MFC-5840CN All-In-One InkJet Printer
Startup problems with the Brother MFC-5840CD All-in-one
When the MFC is plugged in and turned on, there is a grinding sound that comes from the area of the scanner bar. The led readout is" Please Wait..Res: Standard". The machine will cycle through this same process again and again, and never comes on for proper operation. The scanner bar, which usually aligns itself while the scanner is warming up, does not move and the rubber drive belt seems to be trying to drive the scanner bar forward, to no avail. The machine then turns itself off and tries the startup process again. An interesting observation - When the scanner bed and the printer cover is open to be able to look inside, the scanner bar aligns itself as normally the case, but the machine turns off immediately when the cover is placed in the down (normal - closed) position. I spoke with techs at the brother help site, but they were at a loss as to what is happening. Can anyone help?
How do I delete the memory
Posted on May 11, 2012
  • 832 Answers
You have to open the scannerbox very carefully. There is a contact on the lefthandside placed where the motor and belt is located. Check the position of the motor an ohter parts, by carefully sliding the scanner bar by hand. You may need to click in some parts because they have got loosen. Reassemble scannerbox.
Posted on Sep 07, 2007
SOURCE:
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Mar 31, 2014 | Brother MFC Office Equipment & Supplies
I turned on my Brother MFC-7440N and 1. heard a grinding noise then 2. saw the message, "drum end soon" What does this mean?
By the sound of it, it sounds like the drum for the laser printer is just about shot. Time to get another cartdrige.
May 16, 2010 | Brother MFC-7440N Laser Printer
Brother MFC 8840D grinding sound when feeding paper
One or more of the gears on the drive train is damaged, you wil need to take the Printer to a service centre to be repaired.
Aug 03, 2009 | Office Equipment & Supplies
I have a Brother 8640D all in one printer. There is a grinding noise when I go to print. The paper is going through the drum and they getting stuck before coming up and resting on the try where I pick up...
if its going through the drum, then its stopping at the fuser area.
you have a broken gear on the fuser. the fuser will need to be repaired. approx. cost for fuser repair will be about $75.00
Jun 25, 2009 | Brother MFC-8640D Printer
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Squeaking and grinding upon printing.
MFC 240C turned on, and the LED indicates a print jam and a scraping sound, when there is no printer jam.
May 05, 2009 | Brother Multi-Function Center MFC-240C...
Makes loud sounds
I had the same problem with the loud grinding sound. The gears on the cartridge(s) is not turning but rather stripping creating a grinding sound. Reinstall all of the toner cartridges. If that doesn't work, pull each cartridge out and manually turn the gear on the cartridge. If the problem persists, you may need to purchase a new toner cartridge.
Dec 04, 2007 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-425CN
AF after cleaning cycles??????????????????????????
AF means that the scanner flatcable is not connected to the main pcb (When powering up you should hear a grinding sound from the scanner area). Open the scanner cover as for changing the ink carts. Open the small cover (looks like a " L ") and connect the white flat cable simply by pushing it into the main pcb.
Oct 25, 2007 | Brother MFC-425CN Multi-Function Center...
Startup problems with the MFC-5840CN All-in-one
well thisone most techs have to see first. the simple solution is that the cover is binding some where and putting pressure on the scanner bar or its slide rail. my best sugestion is to take it to a printer tech and have them look at it
Aug 16, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
203 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
