Question about NEC Versa LX Notebook
Troubleshoot when I open my laptop nec versa there is no displayed in the screen and a few seconds I hear a three beeps what is the problem of my laptop can you help me!! thank you for your consideration.
    Problem Solver:
  • 6 Answers
3 beeps is the Beep code for "Base 64KB RAM Failure". Lets hope that you are lucky and the problem is your memory. If you have two memory sticks in the computer, then try to take one of them out. Try different combinations such as swapping between the memory slots that are available. If you still getting the same error code, then your motherboard is shot.
Posted on Aug 16, 2007
My NEC Versa 6300 Laptop screen lights momentarily to show the NEC logo on a white background and then goes black. It has even flashed on the desktop for a few seconds before going black. I can connect to...
i would try a new cable before i say it is the screen and you may want to unplug cable from back of screen and make sure it has a good connection there as i have found reseating them has helped on quite a few
Aug 18, 2013 | NEC Computers & Internet
My NEC Versa 3200 laptop screen now keeps on turning bright and then dim for few seconds and then back to bright. It does this few minutes after stat up. Any advice on this, thanks.
Generally a laptop will do that when it changes from AC power to battery power and visa versa. The tendancy is that either the power jack is going bad or the power cord has a broken wire near the head. Another reason laptops do that is if the AC adapter is not rated for the laptop it's being used for. Like, if you were to use a Netbook charger to charge a full size laptop, you will get the same problem. Check the charging cord for and abrasions or cuts and move the wire close to the head around in circles and see if it has a "sweet spot". Take the battery out and try starting the laptop on AC power only. If the problem is in the cord it should shut the laptop down or keep it from coming on. Either way, it's most likely one of those three things. Hope this helps
Sep 02, 2011 | Computers & Internet
When i power on my nec versa e600 the laptop make several long peeps..what can i do...
If you are hearing 3 beeps then you have a faulty or loose memory chip.
Turn the laptop off, remove the power cord and the battery. Turn the laptop upsidedown and look for a panel with a couple of philips screws. Unscrew these screws and access the RAM (memory) bay.
Unclip the memory and clean the brass contacts and the slots.
If there is more than 1 memory module put them back one at a time and try turn the laptop on to see if it boots.
If there is less or more than 3 beeps please let me know how many there are as the length and how many beeps gives us an indication of what the problem is.
Listen carefully at the beeps and try your best to describe them.
Regards.
Jun 22, 2010 | NEC Versa FX Notebook
My compaq laptop F500 has black screen when power on
That sounds like a power supply problem. That would be the first thing I would check. If it was the processor, you would have heard a long beeping sound or if it was the memory you would hear about three 'annoying beeps'. The main reason you indicated there is no display on the screen and that the fan spins for a few seconds then shuts off, would hint that power is not going to the mother board long enough to spin the processor or cooling fan. Hope this helps :)
Apr 17, 2010 | Compaq Presario 700 470024-192 Notebook
I was flashing my motherboard and when it reached 70%, the laptop restarted itself. after the restart the screen is blank. It gives 1 long beep followed by 2 short beeps,keyboard seems to be working ,but...
see if the company offers a boot disk option for flashing your bios. If so make a boot disk and use their flash program. If it's just for windows then your most likely going to have to send it back to them.
Nov 30, 2009 | Office Equipment & Supplies
I bought a second hand NECVALUESTAR VT900/3.Ive install a Windows XP Pro sp3 from its old Version Windows XP home edition ive installed everything find but theres a Black space on both side of the screen...
check your display drivers. whenever you install a new OS, 99% of the time you will need to reinstall a few drivers.
  • open system properties
  • press hardware
  • Device Manager
  • Look for highlighted entries
  • right click and hit update on highlighted device
Sep 13, 2009 | NEC Versa VX Notebook
Need a manual for diassembley of a NEC Versa L2200 notebook
This page should have your manuals :
http://support.necam.com/mobilesolutions/hardware/notebooks/2200/2200man.ASP
Here are all the drivers for your NEC:
http://support.necam.com/drivers/index.cfm?M=475
May 23, 2009 | NEC Versa VX Notebook
NEC Versa Notebook S Series User Guide
Here you go.
NEC Versa VX User Guide
Don't forget to rate my solution FixYa
Thanks!
Mar 01, 2009 | NEC Versa VX Notebook
NEC Versapro Laptop LCD problem
Try an external monitor with your laptop.If that works then you know that your screen is bad. Replace it.
Mar 21, 2008 | NEC Versa FX Notebook
NEC Versa LX Notebook Logo
115 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
