Question about Brother MFC-5840CN All-In-One InkJet Printer
Startup problems with the MFC-5840CN All-in-one
When the MFC is plugged in and turned on, there is a grinding sound that comes from the area of the scanner bar. The led readout is" Please Wait..Res: Standard". The machine will cycle through this same process again and again, and never comes on for proper operation. The scanner bar, which usually aligns itself while the scanner is warming up, does not move and the rubber drive belt seems to be trying to drive the scanner bar forward, to no avail. The machine then turns itself off and tries the startup process again. An interesting observation - When the scanner bed and the printer cover is open to be able to look inside, the scanner bar aligns itself as normally the case, but the machine turns off immediately when the cover is placed in the down (normal - closed) position. I spoke with techs at the brother help site, but they were at a loss as to what is happening. Can anyone help?
    Problem Solver:
  • 18 Answers
Well thisone most techs have to see first. the simple solution is that the cover is binding some where and putting pressure on the scanner bar or its slide rail. my best sugestion is to take it to a printer tech and have them look at it
Posted on Sep 06, 2007
SOURCE:
I need to connect my printer to my computer. It tells me it's not connected I've turned it off and on, I've reinstalled it and it says it's not connected.
You're Brother MFC printer did not come with the printer to computer USB cable. You will have to buy one;
http://www.brother-usa.com/SiteSearch.aspx?sk=5840CN
99% of printers sold do not come with the USB to PC printer data cable. Pick you're length;
https://www.cablesforless.com/c-491-high-speed-usb-printer-cables.aspx
Cheers'
Mike
Feb 19, 2010 | Brother MFC-5840CN All-In-One InkJet...
How to install LAN Brother MFC-5840CN on Windows 7 when original CD only has XP driver. Windows Update list specifies MFC-5840CN USB, but machine has option for LAN - is the driver the right one?
You cannot use the full driver and software package now. BUT:
Printing is possible, scanning and FAX is not possible at the moment. You download the Vista driver (x32 or x64) from the official Brother site and install it with the Printer Wizard in Windows 7.
Oct 28, 2009 | Brother MFC-5840CN All-In-One InkJet...
MFC 5890CN error 36, paper jamming all the time, makes a grinding noise before jamming.
IT SEEMS THAT THE ROLLER IN THE PRINTER IS GONE BAD IF IT IS IN WARRANTY GET IN TOUCH WITH MANUFACTURER AND GET IT REPLACED.
Oct 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
UNABLE to CLEAN is message.
seems to me problem with your ink cartidge
Jul 19, 2009 | Brother MFC-5840CN All-In-One InkJet...
Get paper jam error on Brother MFC 5840CN
are you using brother oem ink? generic ink gives lots of problems
Dec 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
Mfc-640cw
Yes. There is some paper left in the very edge (mostly left hand side). Have a good look there by opening the scanner top.
Feb 27, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother mfc-5840cn
press menu then start mono then 4 times arrow-up (Tel index). machine will be in maintenance mode. press 8 then 0 (zero) then press the start mono button until display shows error A1: xy. Press the right arrow (Speaker +) button. What error codes do you see? (Machine saves the last ten errors). plz post here again.
To leave the maintenance mode press 9 then 9.
Nov 02, 2007 | Brother MFC-5840CN All-In-One InkJet...
Startup problems with the Brother MFC-5840CD All-in-one
You have to open the scannerbox very carefully. There is a contact on the lefthandside placed where the motor and belt is located. Check the position of the motor an ohter parts, by carefully sliding the scanner bar by hand. You may need to click in some parts because they have got loosen. Reassemble scannerbox.
Aug 16, 2007 | Brother MFC-5840CN All-In-One InkJet...
I cannot send nor receive faxes.
Make sure the phone cord from the wall is plugged into the port marked"line" and not "phone".
Apr 29, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
194 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
