Question about Panasonic PT-53WX54 53" Rear Projection HDTV
Convergence my Panasonic PT-53WX54 53 in. Rear Projection HDTV has convergence problems. There is a purple line about 1 in wide on the right side. The picture images gave green/purple ghost shadows around them. I have tried to adjust the convergence but it doesn't help.
  • David Moore Jun 05, 2008
    I have the same TV and same problem.
    Which Ic's need to be replaced and where can they be purchased ?
  • Anonymous Mar 30, 2014
    projected image is coloured purple or green
    Sergeant:
    Champion:
  • 375 Answers
Covergence amp ic"S need to be replaced.
Posted on Aug 18, 2007
Green tint only on left hand side towards the middle of the screen
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 29, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a Panasonic pt-53x42 projection tv. I believe i have a convergence problem. I have double lines running along bottom of screen..Any help please...
Yes,this problems is 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a Panasonic Multimedia Projection HDTV when tv is turned on it has red & blue color spots & red verticle lines showing on the screen what could be causing this to be happening
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have shadows colors pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
We have a PT-47WX51CE panasonic cinemavision hdtv 1080i and the colour is off. We see separated mainly green and magenta and the picture is warped with some lines.
All that mess in picture is due to failure of convergence output chips in this tv.
Replace convergence output ICs (two ICs) to solve picture problem. Required ICs are available in Part Store, click the link to have price info.
Thanks.
Jun 25, 2010 | Panasonic PT-47WX51 47" Rear Projection...
I have a PT-47WX53 that has one vertical bar down the middle of the screen. Barely visible in a purple hue and about 3-4 inches wide. I'm looking for some suggestions. Thanks
A few simple things you may try. Under your menu on the tv look for convergence or it also may be under setup. Run the convergence setup and follow the on screen instructions. If the tv fails to converge while in setup you may need to replace some things however the parts are very very cheap. If your convergence setup works and you still have a bad picture, and or both, meaning the tv's convergence wont align then you may need 1 or 2 IC's and maybe need to change your coolant in the tv's RGB lens...all can be done with little experience and for under 50 bucks. I can give more detail if needed.
Dec 28, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Screen plays double
It is called convergence out IC failure and you need to replace 2, ICs in convergence section of TV.
If you are familiar with TV repair or can solder electronics parts in circuit board then let me know exact model number of Panasonic TV to guide you more with technical info or call local TV repair shop for repair.
Apr 24, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence problem and cropped picture
your tv is under convergence problem usually we need to replace 2 big integrated circuits in the convergence section, at this point you may need a good tech to come over to your home
Nov 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PT47WX52F Convergence problem, 3-d look, green worse
So you are able to adjust? the crosshairs move left and right up and down. you might have to get a tech to adust it in service mode.
Feb 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic blue convergence problem
Yea, you have to have the two convergence Amp IC's replaced. Should run you about 300 bucks or so. Good Luck
Sep 14, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
227 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
