Question about Promise Ultra100 ATA/100 Pci (ultra100 tx2 5 pack) ATA Controller
Mobo reads less ram than windows
Motherboard has more ram installed than the bios is "testing". test reads 32Mb ram, windows properties reads 256Mb ram installed. machine siezes when layered links are used. Spider solitaire delayes. send specs for KT333 8235.
  • 661 Answers
Possible that you have incompatible mem installed, the archictecture of the mem could be 32mb x 64bit could mean that the "BIOS" may only be able to see 32Mb x 8 which to me suggests that this is not the correct mem for this Motherboard, is this mem recovered from another system or an old board. Try Kingston.com and use their memory configurator to find the correct mem for your motherboard (enter the MB manuf and model)
Posted on Aug 17, 2007
SOURCE:
Intel DH55TC Motherboard does not recognize the internal dvd burner in BIOS
Update your MOBOs BIOS. also check the connection points on the mobo to see the SATA connection is impeded or messed up in any way.
Aug 22, 2012 | Intel DH55TC Motherboard
Building desktop: no beeps, no video The mobo LED are on, fan is running but getting no signal to monitor. I've tested the video card in another pc and confirmed working. The only time the mobo beeps...
If the cpu was bad- nothing would turn on--be sure the cable is good-- also be sure the VGA is enabled in the bios- since you cant see the video you have to reset the cmos setting--unplug the unit and remove the cmos battery-reinstall after one minute and check for video
Apr 10, 2010 | Intel Desktop Board D850MD Motherboard
What type and how much memory can i put in the MB MS 6577 Ver 4.1?
1GB Of PC2100/PC1600
According to:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07843
Apr 24, 2009 | Computers & Internet
256MB Video Card only picks up 32MB
just change the display properties in bios settings
Mar 04, 2009 | Leadtek WinFast PX6600 TD GeForce 6800,...
RAM Installation.
your new ram fsb speed not support your mobo
845glly mobo support 266 fsb 133 mhz sdram
Feb 29, 2008 | Intel D845GLLY Motherboard
Ddr2 ignored
the size of the ram is not enough, try increase the size of the ram.
uzowuanya
e-mail: [email protected]
Feb 12, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Bios upgrade?
You might consider replacing your ram with ALL the same RAM cards. I don't know what the maximum RAM is that you can add to your motherboard, but I have read that some BIOS programs can't read cards that are different amounts from others. Don't exceed the recommended RAM for the motherboard, either.
Jan 09, 2008 | Delta Enterprise Slot 1 M81-X Motherboard
Incorrect value on ram
Even if the new memory is 256mb, the motherboard will not read it as such but a max of only 128mb. Alternately, what you need is to get is another 128mb SRAM rated at 100/133 MHz. Sorry to say but yours is a common problem when newer memory are fitted to a relatively not so recent machine.
Good luck and kind regards.
Nov 24, 2007 | Computers & Internet
P4i65G - brand new want start.
Try getting a slower cpu, I have a 3.0Ghz P4 with 512mb of ram and it works great, I emailed them about upgrading ram and they said: "Upgrading the memory would not affect the Video card, unless the memory is not compatible with the motherboard, then the computer might not turn on at all."
Oct 24, 2007 | Asrock P4i65GV Motherboard
Motherboard is dead
remove the RAM. boot minimal only (floppy). get to BIOS screen. reset to factory default. try again with boot floppy. if ok, re-install RAM and repeat
May 31, 2007 | Intel SuperMicro SUPER Motherboard - 810...
Promise Ultra100 ATA/100 Pci (ultra100 tx2 5 pack) ATA Controller Logo
97 people viewed this question
Top Promise Computers & Internet Experts
Ekse
john h
Andrew Taylor
Andrew Taylor
Are you a Promise Computer and Internet Expert? Answer questions, earn points and help others
