Question about Nintendo Wii Console
Black and White Video - Wii Component cable
I am trying to set the Wii TV resolution to 480p. I am using a component cable, and a HD TV. Qll I get is sound and Black and White Video. I tried the TV input with a different device and it works fine. Thoughts? Running Ver 3 on the Wii. Just updated. Problem was there before I updated.
  • emomobile Dec 26, 2008
    I have the same problem, and yes, it is an HDTV, and no, I didn't plug the cables in wrong.
  • collarcounty Jan 20, 2009
    Same problem. My jacks are correct.
Put yellow in video red and white in audio and change source to av
Posted on Jul 08, 2009
  • 752 Answers
Sounds like one of the cables is in the wrong jack. Quite often people will mistakenly put the red video cable in the red AUDIO input thats in close proximity. Also sometimes the green and blue look alike in the shadowy recesses behind tv's.....
Posted on Sep 13, 2007
SOURCE:
Got a brand new hdmi tv, hooked it up to wii, and the main screen is white, color is poor and cannot read anything
The resolution of your TV is over 720 pixels per inch (PPI)
The Nintendo Wii console can only handle 480 PPI
You may need to buy the adapter to hook the console to the HD components (R/G/B) instead of the standard composite (Y/R/W)
Here is one for cheap on Amazon:
480p HD Component Cable for Nintendo Wii
- Matt
Mar 01, 2014 | Nintendo Wii Video Game Consoles & Games
Where to start.....alright. I currently have a softmodded Wii console, and I recently bought third party component cables for it. The cables work fine under Standard TV resolution (480i), but when I change...
From the Wii Channels menu, click the "Wii" button on the lower left of the screen. From there choose: Wii Settings > Screen > TV Resolution. In this menu, click on the "EDTV or HDTV (480p)" option and then click "confirm".
Aug 07, 2013 | Nintendo Wii Console
Screen is flickering after changing tv configuration on settings page
If you've changed your Wii's output setting to 480p but are still using the regular red/white/yellow cable, that could be the problem. 480p output is only possible using the component (red/white/red/blue/green) cable.
May 13, 2012 | Nintendo Wii Console
I have had my wii for a while and it is black and we hooked it up to our flat screen Vizio and it is only in black and white but then when i hook it up to my older tv it is in color and i cant figure out...
Did you use the Component cables for the new tv? If you did, you need to go into the System Menu of the Wii, and change the output to Component 480p, and that should give you a color picture with a higher resolution. Hope this helps!
Feb 23, 2011 | Nintendo Wii Console
Wii game hooked up to new Sharp LED tv. TV is color and the wii is in black and white.
Usually this is either a cable or a mode issue. First make sure that you have the correct cable connections. (Composite video cable to a component video jack is one possible cause of the problem.) Component video cables are not included with the set but will give better results. However, composite video in from the wii's composite video out should give good results.
If you are using HDMI or component video cables, then go into the Wii video menus to select the correct mode for your tv. Check your TV manual and the Wii setup guide for details on the mode (resolution, etc) you should be using.
If the problem persists, try new video cables and make sure that they are fully seated on both sides. Try switching inputs if you have several available.
I hope this helps.
Jan 22, 2011 | Nintendo Wii Console
My new set displays only 480p SD on all my HD channels. Am I missing some settings in the menu's or is something more sinister going on? Any help would be greatful, I'm drowning watching sports!
hi,
u can enjoy full hd 1080p video through only ur tv inputs as 2 component video and 2 HDMI. the tv is seted to receive videos up to the resolution 1080p automatically (need not have any setting). just check the output of ur cable box or BD player, is it outputs full hd. if u are using the tvs internal tuner u will only get 480p.
ok
Dec 20, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
I dont get the hd tv choice even though my tv is hd
The wii does not support HDTV resolutions, it only supports EDTV which is a resolution of 480p. If you want to get a clearer resolution than a simple scart interface you will need to purchase a wii component cable (you can get them off amazon/ebay) that has 6 jacks you can plug into the component slots on the back of the television.
Dec 31, 2009 | Nintendo Wii Console
I want to buy the kids a wii for xmas. They have a samsung rear projection t.v that platys their xbox, will it play their wii?
Look at the inputs panel to your TV. If it has an extra composite input (red, yellow, white), you will be able to use the Wii right out of the box.
If it has component inputs (red, blue, green), it will work at a higher resolution (480p vs. 480i), but you will need to purchase a component video cable for Wii. A regular component video cable will not work.
Good luck.
Nov 18, 2009 | Nintendo Wii Console
Static verticle lines on screen
wiis dont do that but many tvs do im sure its the tv not the wii so it wont matter
May 21, 2009 | Nintendo Wii Console
Wii console to Philips HDTV Connection not working
In order to use the 480p (HDTV/EDTV) resolution, you MUST be using the Wii Component Video Cable. Any other cable will not display the 480p resolution, you have use the 480i (Standard) instead. You can order the Wii Component Video Cable through Nintendo's Web site. Using that cable, you can select the 480p resolution. Hope this helps.
Jan 26, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
2,626 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
