Question about Sony Handycam DCR-TRV310 Digital Camcorder
No response at all from Camera
I purchased the camera in 1999 and it has been flawless. The last time I used it it worked fine - then i shut it off for a few minutes and it would not come back on. I have tried two batteries and there is no difference. When I plug in the AC power nothing happens - the screen on the side that usually lights up and tells the percentage of charge stay off completely. Is there a fuse or reset button that can be replaced. It seems odd that it had a complete failure??
  • Anonymous Nov 17, 2007
    No power, batteries charged fine three days before. Spare battery no go. Will not work with external power either. I charged the CR2025 battery to no effect.
  • 73 Answers
A flexible connector cable may have worked loose , causing the camera to not power up - or , any of a number of microfuses may have opened to protect your camera but none of it is user serviceable ( near 8 years of flawless use says - you have taken excellent care of it );
Posted on Aug 16, 2007
  • Anonymous Aug 16, 2007
    it maybe is time , for a smaller back - up camera
SOURCE:
Lens error message? Worked fine the last time I
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Jul 27, 2010 | Canon Powershot A2000 IS Digital Camera
Fuji Finepix 470batteries only last a very short time. Previously
Most of time it is a battery problem.... try with another battery, before purchasing new one....
If another battery does not works then get it serviced.
Battery has certain time period life (mostly it is expressed in, "no. of times charge") after that battery power deteriorates...
Or if battery has been water clogged then also battery power deteriorates.... (for water clogging may happens exposure of battery to humid conditions)
Please rate the answer if you find it useful...
thanks for rating....
Apr 29, 2010 | Fuji FinePix 4700 Zoom Digital Camera
Camera does not respond
I suggest you open the battery compartment and check the connections on the battery. It may be that they are a little dirty, preventing proper electrical connection, in which case you can clean them with a little cotton bud and perhaps some methylated spitits.
Mar 15, 2009 | Casio Exilim EX-Z50 Digital Camera
My Canon sd 1000 won't power on. Battery is OK.
Check to make sure the batteries you are using have enough strength and volt power, if not it wont work. If they are really cheap, and last only a weak in the remote, they wont power up a camera.
Jan 21, 2009 | Canon PowerShot S1 IS Digital Camera
Largan Easy 200 Digital Camera
you have to have the cam on .. when you plug it in to the usb port... then it looks like it shuts off and any were from a few sec to a few min. it will popup on the screen asking what you want to open
Jan 09, 2008 | Largan Easy 200 Digital Camera
DiMage Z6 turns off when trying to view pictures
I posted this on another section:
My Z6 worked flawlessly for over a year, then suddenly started shutting off for no reason. Tried new batteries, etc. The problem turned out to be the memory card. My advice, buy a GOOD card instead of a new camera! Keep in mind, flash cards DO have a "life" to them - meaning they can only be used / erased so many times before they will cause errors (so don't buy a used card off of ebay - no matter HOW good the deal seems). If your shutdown problem started with a "unable to read card" warning, then its the card. The camera is actually "protecting" itself by shutting down. Good luck!
Nov 25, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Camera keeps turning on and off
HI, Try Replacing Battery . I hope It will Solve the problem. All teh Best Sangita
Jul 10, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Battery?
i just got mine today, and the batteries were dead withtin a couple of hours, so yes. mines has decided to go black, it was fun while it lasted,, theres £90 ill never see again
Aug 24, 2006 | Samsung Digimax S500 Digital Camera
Sony Handycam DCR-TRV310 Digital Camcorder Logo
59 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
