Hello brian _I_kilm, there are (4) four different ways to connect to the Internet.
1) To start, click on the "Start" button.
In the (right "start menu" pane), select the Control Panel shortcut.
Once the next window open; scroll to find, Network and Internet,
click on it to open. Next, select to open the "Internet Options."
To setup the Internet Connection: Click on the "Connections" block, click the ("Setup") button, and follow all the instruction carefully.
2) From the "Start Menu" in the (right) pane, if you have the "Connect To: Icon, click on the icon to open; "this will start the setup and connection process."
3) Click on the "Start" button, select to open "All Programs," next scroll to find: the Product's name; example (Toshiba), click to open. "If there is a ConfigFree icon present? Option is available?"
Select to open, and click on the Connectivity Doctor, follow all instructions thereafter.
4) From the "Start Menu," click on the "All Programs" scroll to find: Accessories.
Select to open and check to see if you have the [Windows Mobility Center]?
Open the program. There will be a Wireless Network {Turn-on / Off} Switch.
Did this solution help? If so; "helpful Rating Feedback is appreciated, thanks paul7of9.
I cant do that my parents computer is plugged into the modem...and theres has the same problem.
Are they plugged directly into the modem or the Linksys router ? Try connecting thier computer right into the modem and reboot both their computer and the modem. Let me know what happens then..
Please try plugging your computer right into the modem. This will eliminate your linksys router, which is a very common reason to this problem.
