Question about Microsoft Wireless Notebook Optical Mouse VSBX300008
Wireless mouse how do i setup the wireless mouse to my computer
  • 1 more comment
  • Anonymous May 18, 2008
    Does the wireles mouse work with Windows Vista?
    Mouse behaves irradically. Why?
  • reading200 Jun 08, 2008
    how do i set up the mousse cause i have no instructions please
  • Anonymous Aug 26, 2008
    how can i set up the wireless mouse to computer
    Scholar:
  • 130 Answers
With USB wireless mice, you plug in the USB wireless adapter, and turn on the mouse. Windows XP should automatically install the software, if not, install the software on the disk that the mouse came with (if there is one). If there isn't a disk, Windows XP will most likely install the drivers automatically. Press the connect button on both the mouse, and the USB adapter, and it should all work. Good Luck
Posted on Aug 17, 2007
SOURCE:
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
My wireless mouse wont work
The wireless mouse functions with batteries. Snap open the location area at buttom of mouse to either check for misalligned batteries or dead batteries requiring replacement. Also, the wireless mouse has an adpater cable that is connected to the computer USB area from where signals are acquired during functionality. Make sure every connectable cables to the computer are firmly in place. Sometimes, the computer may require restarting to capture wireless establishments if an disconnections were encountered once computer was still on. Make sure every connectables are firmly in place, restart the computer for desired functionality. Also, a restart of the computer should diagnose the malfunction of mouse attachements. Improtant notes: A new wireless mouse may have required installation of softwares, opening the computer wireless devices estblihment area to regulate captions on the new setup priop to first acquisition of wireless mouse functionality. Good luck
Jan 11, 2011 | Microsoft Wireless Laser Mouse 6000 v2.0
My son moved the dell wireless keyboard and mouse from our home computer to use in his room now I cannot get it to work on our home computer again. Help
Please follow the bellow steps to setup the wireless mouse and keyboard again.
1) Check whether the batteries are working in the both device.
2) Connect the 3rd kit with the PC in the USB port (receiver).
3) Press the knob for wireless activation on the receiver along with the same of the keyboard (back side of the keyboard) for 4-5 seconds. It will activate keyboard.
4. Now press the wireless knob of the keyboard as well as of the mouse - mouse will start to work along with keyboard.
Hope the solution will work fine.
Thanks for using FixYa.
Jul 13, 2010 | Dell Wireless Keyboard Optical Mouse w0147
I just received a new wireless keyboard and mouse and there are no instructions for installing. It just says to see system setup.
Go to hardware/software manager and click the check mark so the wirless keyboard and mouse can actually gain access to your computer
Aug 14, 2009 | Dell Wireless Keyboard Optical Mouse w0147
We have a 1027 wireless microsoft keyboard and a mouse
Go into your Control Panel, and select the icons (seperatly ofcourse) for your mouse and keyboard and make sure they are in the list for each and are activated. Also, uninstall the drivers for them, and re-install them with the disc provided that came with them. I hope this works for you. Also, after uninstalling the drivers and software, restart the computer, then insert the disc and run setup.
Apr 01, 2009 | Microsoft Wireless Optical Mouse
Wireless Mouse 6000 controlling two computers
Try setting each one up from the start with the other disconnected and off. Start with yours first since it seems your receiver has synced with her mouse. I'm guessing because yours was setup second.
Jan 07, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Wireless mouse
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Check to make sure they are set properly.
Hope this helps. Bud
Jan 01, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Need to attach wireless mouse
This is a simple procedure
Your wireless mouse will have a bass unit that connects to the PS2 port or USB port of the computer
You will then need to load the driver for your mouse
Use your setup CD if you have one.
Thank you for choosing FixYa!
Az.
Sep 19, 2008 | Computers & Internet
Wireless mouse
INSTALLING THE MOUSE
STEP 1 - Battery Installation:
The first step in installing your Wireless Wheel Mouse is to install the batteries.
1 - Locate the two AAA sized 1.5 Volt batteries that came in your Wireless Wheel Mouse package.
2 - Remove the battery compartment cover located on top of your mouse by pressing the cover release button and sliding the cover backwards.
3 - Install the two batteries into the compartment paying close attention to proper polarities.
4 - Replace the battery compartment cover.
STEP 2 - Connecting the Receiver:
If you are connecting the mouse to a notebook that has an onboard pointing device or if you are using a keyboard with an onboard pointing device, you may need to
disable that device before installing and using the mouse.
Sep 14, 2008 | Computers & Internet
Microsoft Wireless Notebook Optical Mouse VSBX300008 Logo
350 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
