Question about SanDisk Sansa e200 MP3 Player
Problems with Sansa e250
I've had my Sansa since the beginning of February...It worked fine until I got a bad track on it. Ever since then, about half the songs ( I usually have about 300-400 songs on it) say "bad track" and they won't delete...Then I went to add songs to it and delete the bad ones off. I disconnected it from the computer and turned it on after it refreshed, only to find it doubled every song and all of the doubles were "bad tracks". I searched the folders and the only way I could delete the bad double was deleting the working original and it keeps doing that...Does any1 have any advice for me? Cuz personally, I'm about to trash it!
  • 4 more comments
  • coffeechick Dec 02, 2007
    My sansa was working fine, until literally one morning, all of a sudden, nearly every track was a "bad track". I tried deleting all the songs using my computer, but most of the songs couldn't even be deleted. Now, I turn on my sansa and it tells me the front logo won't load and i have to go to recovery mode. So i do. And I don't know WHY i was to do this, but it did nothing for me. I'm brainstorming creative ways to destroy this sansa.. so far i've decided on either slow roasting it, or using it as a badminton birdie...but if anyone has any idea of how to fix the problem, or more creative ways to destroy my sansa, please let me know.
  • jhenry922 Dec 13, 2007
    Yes, I had a similar problem with it. It has a bad track listing for Husker Dus Zen Arcade, and Windows XP won't allow me to delete it.
  • TRUE1 Dec 16, 2007
    My Sansa also displays a few songs that indicate "bad track" and I can't find a way to delete those few songsoff my player?? They do not show anywhere when I plug it in.
  • Anonymous Jan 09, 2008
    froze
  • Anonymous Jan 12, 2008
    froze
  • Kagaly1222 Feb 20, 2008
    i have somewhat the same problem. my sansa was all good and fine until one day i decided to make some of my songs onto my 'go list'. then, the next time i went to listen to one of the songs off of it, it said bad track... now all the songs from that album have bad track on them. i am also not able to find them, let alone delete them off my sansa! it is extremely frustrating, and i don't want whatever is happening to get worse... help?!?
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
Bad track appears
Do yourselves a favor. Convert all of the affected tracks to mp3 format (or redownload them in mp3 format), and you will no longer experience these problems.
-Tha Mp3 Doctor
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
BAD TRACK FOR EVERY SONG
The database has been corrupted, click HERE for how to properly format and reload firmware if need be...
Sep 30, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 not working properly
The songs you are trying to use are in the wrong format, or have expired licenses - use mp3 format only and you won't have those problems
Aug 12, 2008 | SanDisk Sansa e250 MP3 Player
Sansa bad tracks and deleting songs.
That Happened to me once. You have to Format the player then it works like a charm.
Feb 23, 2008 | SanDisk Sansa e250 MP3 Player
hold the power button for 20-30 seconds and that will reset the player
Nov 02, 2007 | SanDisk Sansa e250 MP3 Player
Cant get my sansa to shut off
This is a freeze issue. Let it eventually just run down on betteries and be sure you only add tracks which are formatted for the Sansa to be able to play. If there is a reset button combo in the manual, use that otherwise draining the battery will work... Thanks!
Jul 27, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 keeps shutting down
try and see if it is in MY COMPUTER if it is there download the newest firmware and update it if that doesn't work uninstall the mp3 player from your computer and then installit again.
May 20, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
I did not get the "Swtich to Recovery mode" screen, my screen was stuck on "Bad Track." I formatted the drive (which deleted EVERYTHING), and then i put the songs back on, and it works just fine. Try this, it might help.
May 07, 2007 | SanDisk Sansa e250 MP3 Player
Sansa frozen
try taking off the back plate and take out the battery then put it back in and turn it on
Feb 08, 2007 | SanDisk Sansa e250 MP3 Player
E250--several problems lol
it could be either a bad usb hub or cord for the sandisk e250, but it would most likely be that one of your CD's is either corupted, or your sandisk detects a virus and is skipping through the song.
Jan 08, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
82 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
