Question about Polaroid i639M Digital Camera
Polaroid Screen Everytime I take a picture, even in broad daylight and with a flash, it shows up on the camera screen (and my computer) completely black. How can I fix this?
  • leesuh Aug 16, 2007
    Also, I can view pictures that I'd taken before this problem occured, so I don't think it's my screen.
There may be something wrong with a chip inside of your camera.
Posted on Mar 29, 2008
Nikon D5100 dark screen on live view mode
Open your appuatue set your ISO to 200 or 1600 what ever it needs
Feb 20, 2014 | Nikon D5100 Digital Camera
With what can i cover a polaroid flash
The Polaroid 600 doesn't have an automatic flash. To use the flash, insert the flash bar into the flash socket. To turn off the flash, remove the flash bar. Refer to the manual.
If you have a different camera, please reply to this post and give the model number.
Feb 02, 2012 | Polaroid 600 Film Camera
My a930 polaroid does not focus well at all what can I do??
This could very well just be the nature of the camera-- are you attempting to take pictures in low light? This can cause difficulty for the camera to focus. If the camera is having trouble focusing in broad daylight, then there is likely some problem with the autofocus system that would need to be examined by a camera repair shop. The repair on a point and shoot camera like this one would likely exceed the value of the camera.
Mar 10, 2011 | Polaroid a930 Digital Camera
Battery level don't show on display.
hi friend,
follow these steps
  1. Turn off your LCD display screen. I know this is hard—who likes shoving their face against the camera to compose a shot through the little viewfinder? But the LCD screen single-handed-ly drains a lot of power.
  2. Minimize the picture preview to the least amount of time possible—usually one second. This uses less LCD screen time, thus less power.
  3. Dim the brightness on your LCD screen. A dimmer display extends battery life by consuming less power to light the screen. This might make the display harder to see, but usually only in direct sunlight.
  4. Set the power saver to the least amount of time. Power saver lets your digital camera “sleep” when not in use, but doesn’t shut it down entirely. To “wake up” your digital camera, simply click the shutter button.
  5. Use your zoom as little as possible. The motor that moves the lens uses power. This also goes for repeatedly turning your digital camera on and off if it has an extend able lens.
  6. Turn off the continuous focus. Again, constantly using motors and electronics to ready your shot drastically minimizes battery life.
  7. Don’t push the shutter button half-way down until you’re ready to shoot. Pushing the shutter button (constantly resetting and refocusing) will drain battery life.
  8. Use the flash only when necessary. Your digital camera’s “auto flash” option should take care of this, but make sure your flash isn’t going off in broad daylight.
  9. Don’t delete pictures from your digital camera unless necessary. This consumes power. Wait until you download the pictures to your computer before deleting.
  10. This one’s basic, but charge your battery often. Lithium ion batteries, which most digital cameras use, don’t have “battery memory” like older alkaline. In fact, lithium ions work better and last longer if charged completely and regularly.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Light or white picture when shot on a broad daylight or on a well-lighted area
Are you in any other mode besides automatic when this happens. If you're not sure, check that the rotator dial is set to the first little red camera right next to the blue arrow (this is the automatic position). If you're in this position then it's unlikely that overexposure will occur unless you're also encountering mechanical failure of a stuck shutter.
May 27, 2009 | Canon PowerShot A460 Digital Camera
White screen when taking pictures in daylight
Go to the menu screen for LCD contrast and adjust, it sounds like it is to high. Kinda like a back light for a plasma screen.
Oct 23, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera Ready and Flash
I'f your using alkaline AAs, try using rechargeable NiMH batteries or lithium disposables. Alkalines are very poor at supplying the kind of current needed to recharge the flash. I've found other Samsung cameras to be particularly fussy about batteries, and not always consistently so! Good luck.
Sep 05, 2008 | Samsung Digimax A402 Digital Camera
Blurry white image when pics are taken during broad daylight
Try first to reset your camera. Press the menu button, go over to setup, go down to reset, press the right arrow, highlight reset and press set. Don't worry it won't erase any of the pictures on your memory card. If that doesn't work you can try and manually set the white balance on your camera and I would recommend sending it into repairs if that doesn't work since it's taking nighttime pictures fine. :)
Dec 07, 2007 | Casio Exilim EX-Z55 Digital Camera
Polaroid a520 doulble flash
The first flash is to lessen red eye in picture when 2nd flash goes off.
Nov 22, 2007 | Polaroid PhotoMax PDC 4055 Digital Camera
The lcd screen on my polaroid i533 digital camera went out
your screen is broken, some one must have accidentally put pressure on just the screen. The smae thing happened to my screen now i am looking to buy a new screen
Oct 27, 2007 | Polaroid I533P Digital Camera
Polaroid i639M Digital Camera Logo
67 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
