Question about Nokia 6111 Cellular Phone
It will not charge
Hi i have had my nokia 6111 for bout 6 months and not had a problem till now when i plug my charger in the phone the light on the charger goes off and the phone does not charge i have tryed other chargers but still it does not charge.
  • 7 Answers
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. click here Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. 5. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models. click here
Posted on Aug 26, 2007
SOURCE:
My Lumia 520 is dead! It wouldn't charge, so I bought a new battery, the battery worked till it drained now it won't do anything. Checked the battery points & charger entry, don't know what else to do
Hi , you have to check that you might need a new battery charger. The new battery the bought had a charge then you used it up it sounds like your charger might have the light on but is not charging.
Dec 27, 2015 | Nokia 5700 Cellular Phone
Where do i plug the charger on the phone
ya,there is a downside whole is there there you can plug in charger.
May 03, 2011 | Nokia 6111 Cellular Phone
Hi i bought a nokia n97 almost a month ago,and one time i went to bed and left it to charge and woke up with the charger not working. ive been told its an electrical problem so i changed the charger,now...
In the manual with my Nokia 5230 Nokia says that when the indicator gives a sign about the unit being fully charged one is supposed first to take charger connected to the phone first and then the plug from the electricity. Take another look at the manual of your phone and checkonthe information on charging
Jun 13, 2010 | Nokia N97 Cell Phone
Charging problem - battery?
Try an Antec charger with an adjustable votage output. I tried a new battery, charger, BIOS udate, etc, etc, etc. After fighting it for about 2 months, I found the Antec at Best Buy. Took it home, plugged it in, slid the adjuster up till the "charge" light came on. Been working fine for about 6 months.
Dec 27, 2009 | Fujitsu Computers & Internet
Problem with charging nokia 5800
If your phone was bought in the last 6 months you can go to nokia care center and demand for a new battery and charger or repair the existing ones provided you have the warranty card.You should get it done for free of cost.If 6 months exceeded then
Did u try another charger of the same mobile company,if yes ,and it works ,the problem is with your charger.You can either buy a new charger or get an all battery charger ,a china piece that recharges all batteries of any mobile company.You can get it below 2$ .
If your battery doesn't charge even with other charger of the same company then the problem is with your battery.If you are a nokia user ,here is the price list of all nokia batteries.
http://www.priceindia.in/mobile-phone/nokia-battery/
Sep 17, 2009 | Nokia 5800 XpressMusic Smartphone
How / where do i install the battery in a Nokia 6111?
The battery goes at the back of the camera,you have to press the read button near the charger to pop the back of?
Oct 23, 2008 | Nokia 6111 Cellular Phone
Phones gone stupid :(
No if you had stored the pic in the memory card , if not you lose all the data as the phone software is corrupted you need to reinstall the software from the local phone service center this will fix the issue...................................
Jun 02, 2008 | Nokia 6111 Cellular Phone
Nokia 6111
change ur charger it deducts the problem weather in charer or port
Mar 21, 2008 | Nokia 6111 Cellular Phone
Nokia 6111 Cellular Phone Logo
169 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
